LukeOD
- 6
Hi, I'm half way through a piece of differential equations coursework and I'm having serious trouble with a couple of things.
The brief of the coursework is to investigate the effects of air resistance on falling objects by conducting an experiment to obtain a set of results, then using differential equations to attempt to model the situation. I have been told to first try the relationship 'R is proportional to v', come up with a differential equation, solve it and then use the resulting equation to come up with a set of predictions which I can compare with my experimental results. I've then been told to do the same using the relationship 'R is proportional to v^2'.
The first problem I've got is that I've done all of this but have no idea whether the equations I've ended up with are correct.
The second problem is that the resulting equations [solved for s because my experimental data are times to fall a given distance] contain a constant of proportionality k (from what I've read I think this is something to do with cross-sectional area and air density, but I' not required to know or use this for the coursework). I wanted to rearrange my equations and solve them for k and then substitute my results in and compare the variation in k, but since I can't do this I've tried substituting an experimental value for time and then using trial and error to find the value of k that gives my experimental value for s. I've then used this value of k to make the rest of the predictions. I've got 3 sets of data for 3 different masses [same cross-sectional area] and I've used a different value of k for each set. The problem is that the both models seem to predict the data fairly well, and I expected only the v^2 to do this.
Should I be using the same value of k for all 3 sets? I've tried this and both models disagree with the results quite a lot, and by roughly the same amount.
Can anyone give me some advice and check my derivations please? I've got them typed up in word but can't post them here because the formatting doesn't work and there's about 6 pages. I can email them or attach them to a PM maybe?
Thanks in advance
EDIT:
this is what I ended up with for 'R is proportional to v'
s = mg/k ( m/k e^(-k/m t)-m/k+t)
and this is what I ended up with for 'R is proportional to v^2'
s = m/k∙ln((e^((k√(mg/k))/m t)+e^(-(k√(mg/k))/m t))/2)
EDIT 2:
apologies for the typo in the title!
Thanks in advance
EDIT:
EDIT 2:
