mathi85
- 41
Hi!
I would like to ask anyone with some spare time to check my assignment questions. Last time I was asked to post one task at a time so I will.
Thank you in advance for your time.
Task 3:
A capacitor C is charged by applying a steady voltage E through a resistance R. The p.d. between the plates, V, is given by the differential equation:
CR(dV/dt)+V=E
a) Solve the equation for E given that when time t=0, V=0.
b) Evaluate voltage V when E=50V , C=10μF, R=200kΩ and t=1.2s
Solution:
a)
I want: (dV/dt)PV=Q
CR(dV/dt)+V=E /:(CR)
(dV/dt)+(1/CR)V=E/(CR)
P=1/(CR) and Q=E/(CR)
Integrating factor =e∫ P dt
∫ P dt=∫ 1/(CR) dt = ln(CR)t
IF=eln(CR)t=CRt
y(IF)=∫ (IF)*Q dx
∴V(IF)=∫ (IF)*Q dt
VCRt=∫ CRt*(E/(CR)) dt
VCRt=∫ tE dt
VCRt=(Et2)/2+c
General Solution:
VCRt=(1/2)Et2+c
t=0 when V=0
∴0=0+c
c=0
Particular Solution:
VCRt=(1/2)Et2 /*2
2VCRt=Et2 /:t2
E=(2VCRt)/(t2)
b)
VCRt=(1/2)Et2 /:CRt
∴V=(1/2)[(Et2)/(CRt)]
V=(1/2)[(50*1.22)/(10*10-6*200*103*1.2)]
V=30volts
Task 3:
CR(dV/dt)+V=E
Solution:
a)
I want: (dV/dt)PV=Q
IF=eln(CR)t=CRt
y(IF)=∫ (IF)*Q dx
∴V(IF)=∫ (IF)*Q dt
VCRt=∫ tE dt
VCRt=(Et2)/2+c
General Solution:
VCRt=(1/2)Et2+c
t=0 when V=0
∴0=0+c
c=0
VCRt=(1/2)Et2 /*2
2VCRt=Et2 /:t2
E=(2VCRt)/(t2)
b)
VCRt=(1/2)Et2 /:CRt
V=30volts
