A Differential Geometry Class: Suggestions Welcome
TyP
TL;DR Summary
On-Line class suggestions
Can anyone recommend a good on-line class for differential geometry? I'd like to start studying GR but want a good background in differential geometry before doing so. Many thanks.
Maybe @jedishrfu has some idea because he normally has a good overview of online video sources.
This topic is much harder to find courses on as I’ve tried in the past. However, I did find the MIT Open Courseware course:
https://ocw.mit.edu/courses/mathematics/18-950-differential-geometry-fall-2008/
or this course by Prof Arezzo which looks pretty thorough:
and some more visual ones on YouTube which I like because of the relative shortness of the videos and the use of interactive graphics:
My differential Geometry knowledge is somewhat dated with many cobwebs. I learned pieces from an independent studies in General Relativity and in math using Wheeler‘s Gravitation and McConnell’s Dover book on the subject. More recently I looked at Flanders book on Differential Forms but had no time to really get into it.
Personally, I would check out the last selection by Faculty of Khan and then slog through the larger format Prof Arezzo for greater understanding and lastly the MIT one to complete your understanding. I believe they are all at the undergrad level so I guess after that one would tackle the relevant books like Wheelers and Flanders.
Many thanks for all the info.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
