Differential pair, current mirror: high frequency analysis
The discussion focuses on the high-frequency response of MOSFET and BJT differential pairs when polarized by a current mirror. It highlights that the bypass capacitor Cgdm is significant at lower frequencies compared to the internal capacitances of the transistors. The internal capacitance of the current mirror is noted to dominate the low-frequency response, acting similarly to a bypass capacitor. A key point raised is the difference in frequency behavior between the capacitance of the current mirror and the internal capacitances of the main transistors. The Sedra-Smith book is referenced, explaining that the interaction between 2r0 and Cgdm results in a low-frequency zero, allowing other internal capacitances to be treated as open circuits.
eliotsbowe
Hello, I have a doubt about the high frequency response of the MOSFET (or BJT as well) differential couple in the case it's polarized by a current mirror.
Here's a picture of my issue (it shows the semi-differential circuit of a MOSFET differential couple with a "small" common mode ac input; the current mirror was replaced by its high frequency small signal model)
http://s3.postimage.org/x84o1dsxv/asdasd.jpg
The picture says (sorry for posting a non-english text) that Cgdm is to be considered a bypass capacitor and the MOSFET should be replaced by its low frequency (!) small signal model.
The sense of this is that Cgdm "exists" at much lower frequencies than the internal capacitances of the MOSFETs composing the differential couple.
I found the same statement about the BJT differential couple (with a BJT-based current mirror connected to the emitter): the internal capacitance of the mirror dominates the low frequency response of the whole circuit and it acts like a bypass capacitor.
So, my question is: why is there such a difference between the "life" (on the frequency axis) of the capacitance of the mirror and the one of the internal capacitances of the two main transistors?
Thanks in advance for your help.
I found it. The Sedra-Smith's book says that the interaction between 2r0 and Cgdm creates a low frequency zero. Every other internal capacitance is to be considered as an open circuit, then.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
