I Differential structures over a topological manifold
cianfa72
TL;DR Summary
About the definition of different differential structures over a given topological manifold
Given a topological manifold, this may or may not admit a ##C^1## atlas (i.e. starting from its maximal atlas it is or it isn't possible to rip charts from it to get an atlas of ##C^1## compatible charts).
A theorem due to Whitney states that from such a topological manifold ##C^1##-atlas (if any) is always feasible to rip charts to get a ##C^{\infty}## atlas.
My question is: starting from such a ##C^1## atlas could there be the case that one can "extract" two different ##C^{\infty}## atlases whose charts are not compatible each other (even when the differential structures they define turn out to be diffeomorphic) ?
A "C^k differentiable structure" is the same thing as a maximal atlas of C^k compatible atlases.
It should be fairly easy to show that if the identity is a C^k diffeomorphism between two C^k atlases then those atlases are C^k compatible, and therefore part of the same maximal atlas.
Yes of course. However I'm not sure how it answers my OP question though.
Namely: could there be two non compatible ##C^{\infty}## atlases "extracted" from the same ##C^1## maximal atlas (by ripping charts from it as Whitney's theorem implies) ?
Take for example ##M=\mathbb R## and a function that is invertible and ##C^1##, and so is its inverse, but they are not ##C^2##. I think ##f(x)=x^{\frac53}## will do. Then the two charts ##(\mathbb R, Id)## and ##(\mathbb R, f)## are ##C^1## compatible, but not ##C^2##. So they belong to the same maximal ##C^1## atlas, and give you two different smooth structures (of course they are diffeomorphic).
Ok, thank you.
Therefore yours is an example of two not ##C^k, k \geq 2##-compatible atlases each of ##C^{\infty}## class that can be "extracted" from the same ##C^1## maximal atlas.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
