Differential Topology: Proving Integral of f*dw=0 and Line Bundle over RPn
In summary: For part (b), we can use the fact that a bundle with k summands is trivial if and only if it has k linearly independent sections. Since the Mobius band has two linearly independent sections (as shown in part (a)), we can see that E ⊕ ... ⊕ E (with k summands) is trivial if and only if k is even.Finally, for part (c), we can use the fact that every real rank 1 bundle over S1 is either trivial or isomorphic to the Mobius band. Since we have already shown that E ⊕ E is trivial, we can use induction to show that E ⊕ ... ⊕ E (with k summands
babak_812
Hi
I would appreciate any help with these problems. Thanks in Advance!
1.Suppose X is the boundary of a manifold W, W is compact, and f : X → Y is a smooth map. Let w be a closed k-form on Y ,
where k = dimX. Prove that if f extends to all of W then integral of f* dw = 0. Assume that
W is orientable.
what I mean by f* is ofcourse the cotangent of f
2.Over RPn = Sn/A, (where A is the antipodal map and Sn is the n-sphere) define a line bundle v where for
every x ∈ Sn the fiber over the equivalence class of x is is the line {tx : t ∈ R}. Show
that v really is a bundle (by defining a sensible bundle atlas) and that it is nontrivial. (for n>=1)
3.Let p : E → S1 be the Mobius band (a real rank 1 bundle over S1).
(a) By constructing two nowhere zero sections of E ⊕ E, prove that E ⊕ E is a trivial
bundle.
(b) Prove that E ⊕ . . . ⊕ E (k summands) is trivial if and only if k is even.
(c) Show that every real rank 1 bundle over S1 over S1 is either trivial or is isomorphic
to the Mobius band.
Hi there,
I would be happy to help with these problems. For the first problem, we can use the fact that f extends to all of W to show that the integral of f*dw is zero. Since W is compact, we can use the fact that the integral of a closed form over a compact manifold is equal to the integral of its boundary. Since X is the boundary of W, we can write the integral as the sum of integrals over X and the interior of W.
Now, since f extends to all of W, we can use the pullback property of integrals to write the integral over W as the integral over X. This means that the integral over the interior of W is equal to zero. Since w is a closed k-form on Y, it is also closed on the interior of W, so the integral of f*dw over the interior of W is equal to zero. Therefore, the integral over X must also be equal to zero, proving that the integral of f*dw is equal to zero.
For the second problem, we can define a sensible bundle atlas for v by considering two open sets on RPn, one containing the north pole and one containing the south pole. On each of these open sets, we can define a local trivialization of v by projecting the line {tx : t ∈ R} onto the open set. These two local trivializations will overlap on the equator of RPn, but since A maps points on the equator to antipodal points, the two local trivializations will agree on the overlap. Therefore, we have a well-defined bundle atlas for v, showing that it is indeed a bundle.
To show that v is nontrivial, we can consider the section s : RPn → v defined by s(x) = [x,1], where [x,1] is the equivalence class of x in v. This section is clearly nonzero at every point on RPn, so v is nontrivial.
For the third problem, we can use the fact that the Mobius band is a nontrivial real rank 1 bundle over S1 to prove the statements. For part (a), we can consider the sections s1(x) = [x,1] and s2(x) = [x,-1] of E ⊕ E. These sections are nonzero at every point on S1, so they form a basis for E ⊕ E, showing that it is
Related to Differential Topology: Proving Integral of f*dw=0 and Line Bundle over RPn
What is differential topology?
Differential topology is a branch of mathematics that studies smooth manifolds and their properties, such as differentiable functions and vector fields. It also involves the study of differential equations and the use of differential calculus to understand geometric structures.
What does it mean to prove the integral of f*dw=0?
In differential topology, the integral of a differential form over a manifold is a numerical value that represents the "size" or "volume" of the form on that manifold. Proving that the integral of f*dw=0 means that the integral of the product of two differential forms, f and dw, is equal to zero. This result can be used to show that certain geometric properties hold for the manifold in question.
What is a line bundle over RPn?
A line bundle over RPn is a mathematical object that assigns a one-dimensional vector space to each point on the real projective space, RPn. It is a type of bundle, which is a topological space that is locally a product space. Line bundles over RPn are important in differential topology because they can be used to study the topology and geometry of RPn.
How is the integral of f*dw=0 related to line bundles over RPn?
The integral of f*dw=0 is closely related to line bundles over RPn because the zero integral result can be used to show that the line bundle is trivial, meaning that it is topologically equivalent to a product space. This is useful in studying the topology and geometry of RPn, as it allows for easier calculations and proofs.
What are some applications of differential topology?
Differential topology has many applications in mathematics and other fields, such as physics and engineering. It is used to study the behavior of dynamical systems, to understand the topology and geometry of complex surfaces, and to analyze and solve differential equations. It also has applications in computer science, particularly in computer graphics and animation.
  • Topology and Analysis
  • Differential Geometry
9K
  • Math Proof Training and Practice
