Differentiate an equation to find the minimum peak of a variable
  • Thread starter Thread starter souky101
    Differentiate
souky101
Summary:: Differentiate an equation to get the minimum peak
I have this equation:
6.3504 = 23.04 ( 1-141978.24XY)^2 + 141978.24X^2
I want to differentiate it with respect to X to get the minimum peak of Y
dy/dx =0
See attached file
Thanks for help
[Moderator's note: moved from a technical forum.]
What work have you done to try to solve this? Did you attempt to differentiate the equation?
souky101 said:
Homework Statement:: 6.3504 = 23.04 ( 1-141978.24XY)^2 + 141978.24X^2
find the minimum peak of y
Relevant Equations:: I have this equation:
I want to differentiate it with respect to X to get the minimum peak of y
dx/dy=0
see attached photo
Thanks for help
differentiate the equation with respect to X to get the minimum peak of y
dx/dy=0
I think you want a local minimum of Y, not a "minimum peak".
And that means dy/dx=0, not dx/dy=0.
For convenience, let's get rid of those numbers and write the equation as
##D= B( 1-Axy)^2 + Cx^2##
So differentiate wrt x. What do you get?
Likes Delta2
Did you try to solve for x ie create a y = f(x) format from there it’s a simple matter to get the dy/dx?
Show your work.
Thanks for your reply
Yes , we can put it in this form:
D=B(1-Axy)^2 + Ax^2
The graph of this equation depends on the constants D and B - but if we differentiate this equation with respect to x , dy/dx =0 , then the constant D will disappear though the graph depends on it ??
See the attached graph
It will come back, trust me.
Do the differentiation and post what you get.
D=B(1-Axy)^2 + Ax^2
dy/dx=0
0=2B(1-Axy)(-Ax(dy/dx) -A y(dx/dx)) +2Ax
=2B(1-Axy)(-Ay)+2Ax
=2B-2BAxy(-Ay) +2Ax
=2B+2BA^2xy^2 +2Ax
souky101 said:
=2B(1-Axy)(-Ay)+2Ax
=2B-2BAxy(-Ay) +2Ax
Check that step.
2B(-Ay)+2BA^2xy^2+2Ax =0
-By+BAxy^2+x=0
-By+BAxy^2+x=0
Ok. You can use that in combination with your original equation, but it is not going to be pretty.
This equation is function of x and y
Now how to get the minimum value of y ?
and this equation is independent of the constant D though the plotted graph shape depends on the constant D ?.
As I posted, combine it with your original equation. Use the equation in post#13 to eliminate x from the equation in post #6.
You should end up with a quadratic in y2.
Thanks for your help - I will try
Thanks again
May I ask you what the name of the text editor you are using to write mathematical equations ?
Thanks for help
Thanks for help
LaTeX.
Click the LaTeX Guide button just below the text entry window.
I did the substitution but the resultant equation still contains the two variables x and y
D=B(1-Axy)^2 +Ax^2 ... (1)
-By+ABxy^2 +x =0 .....(2)
Substitute (2) in (1) :
(1-Axy) = x/By
D=B(x/By)^2 + Ax^2
This equation is still function of 2 variables x and y !
(1-Axy) = x/By
D=B(x/By)^2 + Ax^2
I didn't think I would need to explain that you first have to get eqn 2 into the form x=f(y).
