Differentiation with different variables
In summary, the author is trying to take the derivative of the following integral but is getting confused. The expression \frac{d}{d V} \int_0^t{V(\tau)}d\tau is strange to the author. It is not clear how to interpret it, and it is not clear what it represents.
wilsondd
I'm trying to take the derivative of the following integral
[itex]\frac{d}{d V} \int_0^t{V(\tau)}d\tau[/itex]
FTC will probably be a part of it.
I always get confused when I'm taking the derivative of an integral. I know the answer is not simply [itex] V(t) [/itex] though since the integrating variable is not the same as the variable I am trying to take the derivative with respect to.
I found the expression [itex]\frac{d}{d V} \int_0^t{V(\tau)}d\tau[/itex] a little surprising. I'm not sure how to interpret the [itex]\frac{d}{d V}[/itex]. I would have expected to see [itex]\frac{d}{d t} \int_0^t{V(\tau)}d\tau[/itex] instead. In that case it is exactly the fundamental theorem of calculus and the solution is ##V(t)##.
Note that I would expect the solution to be a function of ##t## because the expression itself is a function of ##t##. ##τ## is a dummy variable used to compute the definite integral - the expression itself is not a function of ##τ##.
Yes, I agree it is weird, but it is part of a calculus of variations problem, and is not a typo or anything.
Thinking more about the problem, if it is legal to bring the derivative inside the integral, then the answer would just be [itex]t[/itex]. This seems odd in the context of the larger problem, though.
Can anybody comment on if this is correct or not. Thanks.
That is not legal. The only thing you can move in and out of integrals is contants.
You could perhaps start with the chain rule.
You may need to provide more information. What does d/dV even mean here? It can't be a derivative, since the thing to the right of it isn't the value at V of some differentiable function. Is it a functional derivative? Does the course you're taking cover the definition of "functional derivative"? Does the book prove a theorem for functional derivatives that is similar to the chain rule?
In Calculus of variations and Optimal Control we talk about "functional derivatives", which are like directional derivatives in function space. So, given a functional
[tex] F(f) = \int_a^b L(f(t)) \, dt,[/tex]
the directional derivative of F(f) in the direction h (also called the Gateaux derivative) is
[tex] DF(f;h) \equiv \frac{d}{d\epsilon} \int_a^b F(f(t) + \epsilon h(t)) \, dt\\
= \int_a^b F^{\prime}(f(t))\cdot h(t) \, dt.[/tex]
In this notation, your functional ##F(V) = \int_0^t V(\tau) \, d\tau## would have directional derivative
[tex] DF(V;h) = \int_0^t h(\tau) \, d\tau.[/tex]
I don't know if that is what you want, but that is what is done in all treatments of Calculus of Variations that I have seen.
[itex]\frac{d}{dV}[/itex] is the derivative with respect to the function [itex]V(t)[/itex].
This is a calculus of variations problem, and the functional is
[itex]\int_0^{t_1}{\mathcal{M}}dt[/itex],
[itex] \mathcal{M} = \int_0^t{V(\tau)}d\tau + \text{other stuff...} [/itex]
What I'm trying to do, is find the equation for
[itex] \frac{d\mathcal{M}}{dV} = \frac{d}{dt} \frac{d\mathcal{M}}{d\dot{V}}[/itex]
which is where the derivative comes from in the first place.
Hope this helps.
Thanks.
FAQ: Differentiation with different variables
What is differentiation with different variables?
Differentiation with different variables is a mathematical process used to find the rate of change of a function with respect to its independent variables. It involves finding the derivative of a function, which represents the slope of the tangent line at a specific point on the graph of the function.
Why is differentiation with different variables important?
Differentiation with different variables is important because it allows us to analyze the behavior of a function and make predictions about its future values. It is also a crucial tool in solving optimization problems and understanding the relationship between different variables in a function.
What are the basic rules of differentiation with different variables?
The basic rules of differentiation with different variables include the power rule, product rule, quotient rule, and chain rule. These rules allow us to find the derivative of more complex functions by breaking them down into simpler components and applying specific formulas.
How is differentiation with different variables applied in real life?
Differentiation with different variables has various applications in real life, such as in physics, economics, and engineering. For example, it is used to calculate the velocity and acceleration of objects in motion, to determine the optimal production level for a company, and to design efficient structures in engineering.
What are some common mistakes to avoid in differentiation with different variables?
Some common mistakes to avoid in differentiation with different variables include incorrect application of the rules, forgetting to include the chain rule when necessary, and not simplifying the derivative expression. It is important to double check your work and practice regularly to avoid these errors.
