Difficult to understand the solution provided in the video (travelling salesman problem)
  • Thread starter Thread starter WMDhamnekar
The discussion focuses on the complexities of understanding the solution to the travelling salesman problem (TSP) as presented in a video, particularly regarding Hamiltonian circuits with length constraints. Participants express confusion about the classification of paths as 'first tour,' 'better tour,' 'inferior tour,' and 'optimal tour,' along with the significance of their respective lengths. The lower bounds for various paths are explained, emphasizing how they are calculated based on the shortest paths between nodes. Additionally, the potential for solving TSP using methods that do not adhere to its strict conditions is acknowledged, with references to integer programming as a broader topic. The conversation highlights the importance of understanding lower bounds and path lengths for effective problem-solving in TSP.
WMDhamnekar
MHB
It is difficult to understand the solution provided in the video to the travelling salesman problem having Hamiltonian circuits with added length constraint.
The travelling salesman problem has been solved in the below given video, but I didn't understand lower bound computed for the following paths.
I also didn't understand the why Path 8,9 10 and 11 have been called 'first tour', 'better tour', 'inferior tour' and 'optimal tour' respectively.
What are the meanings of l=24 for Path 8, l=19 for Path 9, l= 24 for Path 10 and l=16 for Path 11?
Path 4: a,e lb=19,
Path 5:a,b,c lb=16,
Path 6:a,b,d lb=16,
Path 7: a,b,e lb=19,
Path 8:a,b,c,d (e,a) l=24 first tour ,
Path 9: a,b,c,e(d,a) l= 19 (better tour),
Path 10: a,b,d,c (e,a) l=24 (inferior tour),
Path 11: a,b,d,e(c,a) l=16 optimal tour.
Watch the vide here →
Would any member explain me the travelling salesman problem solved in this video?
Can we solve this problem by another method where conditions of the travelling salesman problem is not satisfied?
The condition is the salesman has to visit each city in the tour only once and return to the start city.
Mathematics news on Phys.org
All of them or any in particular or all of the ones below? I'll do a few.
Traversing that branch of the tree from left to right and calculating the total lengths: The first path is 8. The second path is 9, which is better than path 8. The third path is 10, which is longer than path 9. The final path on that branch is 11, which is optimal for that branch.
Those are the actual lengths if you add up those path steps.
Lower bounds:
Before any path steps are assumed, the initial lower bound (ILB) is where we get to use the two lowest for every node, a,b,c,d,e. That is ILB=((ac+ab)+(ba+bc)+(ca+ce)+(de+dc)+(ec+ed))/2 = ((1+3)+(3+6)+(1+2)+(3+4)+(2+3))/2 = 14,
ADDED NOTE: This is a rough estimate guaranteed not to be higher than the true lower bound. It assumes that each node can be entered and left on its two shortest paths. The sum is divided by two because the paths are counted twice (for instance, from a to b and also from b to a).
WMDhamnekar said:
Path 4: a,e lb=19,
The path (ae) is given, so the ILB values of nodes a and e must be changed. Where possible, replace the larger ILB entries for nodes a and b with ae=8. That gives:
lb=((1+8)+(3+6)+(1+2)+(3+4)+(2+8))/2=19
WMDhamnekar said:
Path 5:a,b,c lb=16,
Now, ab and bc are given. ab was already in the ILB of nodes a and b, so that changes nothing. bc was already in the ILB for node b but not for node c. Change the larger entry of node c to bc=6.
((1+3)+(3+6)+(1+6)+(3+4)+(2+3))/2 = 16
Continue in that way and see if it makes sense for the others.
Yes. This is an example of the general subject of integer programming. There has been a large amount of work done on this subject. Entire books have been written on how to solve them.
Likes WMDhamnekar
Is it possible to compute the answer using the node 2 (a,c),node 5(a,c,b) node 6(a,c d), node 7 (a,c,e), node 8(a,c,b,d), node 9 (a,c,d,e), node 10(a,c,d,b),node 11(a,c,d e)? Is that answer viable? Note that in this case, we are violating the condition that 'c' should not be before 'b'
Sure, you can calculate that but it would be wasting time. The best solution that way would only follow the same path as the "b before c" solution in the opposite direction. By insisting that b precede c, the number of possibilities examined is immediately cut in half. That is a great improvement in efficiency.
EDIT: I should have said it would go around in the opposite direction of one of the optimal "b before c" solutions. There might be ties for the optimal solution. Because the costs (path length) are the same in both directions, the "b before c" solutions are the only ones you need to compute. If the cost depended on direction, the "c before b" paths would also need to be included.
EDIT2: Notice that no branch of the tree is trimmed by comparing two lbs. An lb is an optimistic lower bound. Two of them can not be reliably compared. It is only after an actual length. l. to a terminal "leaf" of the tree is determined that a branch can be trimmed by comparing its optimistic lb to an actual length, l. That is why it is important to go down to some terminal leaves early.
I am including this diagram just to preserve what we are discussing:
Likes jim mcnamara and WMDhamnekar
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
