DIffraction vs. Inteference Help
  • Thread starter Thread starter IMGOOD
    Diffraction
Diffraction and interference are distinct phenomena in wave behavior, particularly evident in experiments like the double-slit setup. Diffraction involves the spreading of waves as they pass through a slit, creating multiple wavefronts that can interfere with each other. Interference, on the other hand, is the result of the superposition of these waves, leading to an intensity pattern characterized by constructive and destructive interference. While interference typically involves a limited number of waves, diffraction can be understood as the superposition of an infinite number of waves emanating from various points across the width of a slit. Ultimately, diffraction serves as a broader framework within which interference occurs.
IMGOOD
I know that in a double-slit experiment, the diffraction of the individual slits produces the envelope of the intensity pattern whereas the interference between the waves coming from the slits produces those little wiggles within that envelope.
But what exactly is the difference between diffraction and interference other than how they affect the intensity pattern? Interference make sense to me because, physically, it is just applying the principle of superposition and adding the waves up. But I can't imagine a similar physical picture for diffraction.
Also, how is it possible, in principle, to have interference without diffraction (in the context of slits)?
Science news on Phys.org
Interference is, as you say, adding together of two waves
Diffraction is just one way of creating two different waves.
In a double slit you split the wavefront into two and combine them again, in single slit it is easiest to think of the waves from the two edges of the slit.
Diffraction is just a more general application of the principle of interference.
Most textbooks present interference as the superposition (addition) of just two waves, or possibly a discrete number of waves (2, 3, 4, etc. slits)
In diffraction from a single slit, you have the superposition of an infinite number of waves, from each of the points across the width of the slit. Mathematically, you analyze this by integrating (rather than simply adding) the contributions from the various sections of the slit. In the full analysis of two-slit interference, you integrate over two regions (corresponding to two slits) and then add the two integrals.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
