Dimension of 4x4 Matrix: Find Basis Vectors
  • Thread starter Thread starter DryRun
    Dimension Matrix
DryRun
A= \begin{bmatrix}1 & 1 & 1 & 1 \\ 2 & 1 & 0 & -1 \\ 3 & 4 & 5 & 6 \\ -1 &2 &1&0 \end{bmatrix}Determine the dimension of A and give a set of basis vectors for A.
Dimension of matrix, ref form of matrix.
I reduced the matrix to row echelon form and then the dimension = rank of matrix. Is that correct? I am quite confused about what dimension means. In a 4x4 matrix, maybe dimension is 16? or is it the number of non-zero matrix elements?
Easy way to remember it is:
# of columns - # of non zero rows in rref
So, the dimension of A is the rank of the matrix A?
Yes. In fact, I would consider the term "dimension of a matrix" very strange. The rank of a matrix is the dimension of the image of the matrix.
I think by dimension you mean "nullity" cause our lecturer also used "dimension of a matrix" which was confusing when studying from other sources.
Try plugging your matrix in wolfram and ask for nullity.
In the output it states a "dimension" which is always exactly what I always needed. So maybe that's what it means.
How does your textbook or lecturer or course notes define the term "dimension of a matrix"?
RGV
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
