Dimension of a vector space and its subspaces
In summary, the dimension of a vector space is defined as the number of vectors in a basis for that space, indicating the minimum number of vectors needed to span the space. Subspaces, which are subsets of a vector space that are also vector spaces themselves, have their own dimensions that can be less than or equal to the dimension of the larger space. The relationship between the dimensions of a vector space and its subspaces is crucial in understanding concepts such as linear independence, basis, and the rank-nullity theorem.
Txema
24
TL;DR Summary
Can a vector subspace have the same dimension as the space it is part of?
If so, can such a subspace have a Cartesian equation?
if so, can you give an example.
Thanks in advance;
Txema said:
TL;DR Summary: Can a vector subspace have the same dimension as the space it is part of?
Thanks in advance;
Is this homework?
Technically, a vector space is a subspace of itself. This is sometimes called a trivial subspace or not a proper subspace. See, for example:
https://en.wikipedia.org/wiki/Linear_subspace
Thanks in advance;
If the dimension is finite, then inclusion ##U\subseteq V## AND equal (finite) dimension implies equality ##U=V.## Both properties are required for this conclusion.
If the dimension is infinite, then things are more complicated. For example ##\mathbb{Q}\subseteq \mathbb{R}## has "the same dimension over ##\mathbb{Q}##" as ##\mathbb{Q}(\sqrt{2})\subseteq \mathbb{R}## and ##\mathbb{Q}\subsetneq \mathbb{Q}(\sqrt{2})## but they are obviously not equal. Infinite cardinalities behave different than ordinary numbers.
Likes mathwonk and PeroK
Thanks in advance;
The dimension of a vector space is the number of vectors in its basis.
Each basis of a vector space has the same number of vectors and ##dim(Ssub) \leq dim(S)##.
The Cartesian equation (If it is a scalar product that determines the subspace) is also trivial.
The scalar product with zero vector
##\langle 0,x \rangle=0 \cdot x_1+0 \cdot x_2+...+0 \cdot x_n=0##
That is it in finite dimensional spaces .
When the vector space has infinite dimensions, you can use the property that ##\infty+1## is still ##\infty##.
You can choose the set of all infinite sequences as a vector space ##x=(x_1, x_2, x_3, ... ) \in S##
and all sequences which sum is zero as a subspace ##Ssub## . Its dimension is ##\infty##.
The Cartesian equation in that situation is
##\langle 1,x \rangle=1 \cdot x_1+1 \cdot x_2+...+1 \cdot x_n +...=0##
where 1 is infinite series ##(1, 1, 1, ... )##
All constant sequences ( which all members are the same number ) is a subspace . Its dimension is 1.
e.g. ##(1, 1, 1, ...)##, ##(-4, -4, -4, ... ) ##, ...
A proper, non-trivial, subspace with the same dimension as the space can only be obtained if the vector space is infinite-dimensional.
PeroK said:
Is this homework?
No, I wish, I'm 60 years old.:smile:
Thank you Perok for your answer.
Likes Bosko
fresh_42, Bosko, my question is perfectly answered, thank you very much.
Likes Bosko
This doesn't fit in the question, does it? What are the space and the subspace with the same dimensions?
You are right, I should have written ...
The subspaces are ##\mathbb{Q}(\pi)## and ##\mathbb{Q}(\pi,\sqrt{2})## contained in the rational vector space ##\mathbb{R}.## The dimensions of both subspaces are then equal but the subspaces are not.
fresh_42 said:
It fits perfectly.
The subspaces are ##\mathbb{Q}## and ##\mathbb{Q}(\sqrt{2})## contained in the rational vector space ##\mathbb{R}.## The dimensions of both subspaces are countably infinite, the dimension of ##\mathbb{R}## is uncountable infinite.
I don't understand. What do you mean the dimensions are countably infinite? The dimensions of ##\mathbb{Q}## and ##\mathbb{Q}(\sqrt{2})## over the field ##\mathbb{Q}## are ##1## and ##2##.
But the question ask for a subspace of a space such that their dimensions are the same. So is it possible to have two spaces (over a field ##F##) say ##W\subset V## such that ##dim_FW=dim_FV##? What are the ##W## and ##V## in your example?
I corrected it.
fresh_42 said:
I corrected it.
Still, what are the ##W## and ##V## in your example?
\begin{align*}
\mathrm{F}&=\mathbb{Q}\\
\mathrm{V}&=\mathbb{R}\\
\mathrm{W_1}&=\mathbb{Q}(\pi)\\
\mathrm{W_2}&=\mathbb{Q}(\pi,\sqrt{2})\\
\end{align*}
\begin{align*}
\dim_\mathrm{F} \mathrm{W_1}=\infty = \dim_\mathrm{F} \mathrm{W_2} \wedge \mathrm{W_1}\subsetneq \mathrm{W_2}
\end{align*}
fresh_42 said:
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
Then there is a missing ##\pi## in your first post. Why do you need to include ##\mathbb R##?
I was mistaken. My thought was that ##\mathbb{Q}\subseteq \mathbb{R}## was a vector space and a subspace with an uncountably infinite index. I then confused index and dimension instead of building a correct counterexample.
I know. I am not picking on you. I just thought it would be usfull to the OP if you clarify it. By the way the real numbers as a subspace of the complex numbers, both over the rationals may be an easier example for the OP.
Likes fresh_42
since the dimension of a vector space is the cardinality of a basis, and every basis of a subspace extends to a basis of the containing space, and every set is the index set for a basis of a vector space, a simpler version of this question is whether a proper subset of a set can have the same cardinality.
