Dimension of terms in Lagrangian
In summary, the dimension of terms in a Lagrangian refers to the physical units associated with each term within the Lagrangian framework of field theory. Each term must have the same dimensionality to ensure the overall consistency of the Lagrangian, typically expressed in units of energy times time (or mass times length squared per time squared). This dimensional analysis plays a crucial role in formulating theories, ensuring that equations of motion derived from the Lagrangian are physically meaningful and adhere to the principles of dimensional homogeneity.
zaman786
31
TL;DR Summary
what do we mean by dimensions of terms in lagrangian?
hi, when we say in SM , we can add terms having dimension 4 or less than that- in this to what dimension we are refering ? kindly help how do you measure the dimension of terms in Lagrangian. thanks
Mass dimension, the only physical dimension left once you introduce natural units. And we are talking only about the dimension of the field content - excluding any dimension of constants.
To find the mass dimension of a field, look at its kinetic term, which contains derivatives and that field only. The total mass dimension of the Lagrange density should be 4 (or it would not integrate to a dimensionless action) and derivatives have mass dimension 1 (as length and time have mass dimension -1).
Likes mfb
Example: The kinetic term for a real scalar field has the content ##(\partial \phi)^2##. If ##\phi## has mass dimension ##k##, then this term has mass dimension ##2(k+1)## where the 2 comes from the square and the 1 from the derivative. This needs to be equal to 4 so ##k =1##.
thanks - but length and time has dimension of -1 , so how can we say Mass dimension is the only physical dimension left?
got it - thanks
(∂φ)2 has mass dimension 4.
Yes, what is your point?
The thing is that you know it needs to be 4 in order to have the right mass dimension of the Lagrange density. The question of the OP was how you deduce the mass dimension of the fields. If the field has mass dimension k, then that term has mass dimension 2(k+1) = 4 from which it can be concluded that k = 1.
Yes, length and time have mass dimension -1. They do not have independent dimensions as in SI units.
Recall that action, ##\int d^4 x\,\cal{L}##, should be dimensionless.
Literally what I already said …
Sorry, I was referring to the OP. You indeed mentioned it first.
got it- thanks
now, in SM Lagrangian terms has dimension 4 - than how do we allow dimension 5 operator in SM , i know it is some what related as perturbation to SM.
The SM as such has only d=4 operators. If you do SM effective field theory you will typically add operators of higher dimension. In the Lagrangian these will be accompanied by a dimensional prefactor, typically assumed to be the mass scale of new physics to an appropriate power.
Likes zaman786
thanks - but as say action should be dimensionless - so if we introduce dimension 5 operator , than do we have to introduce dimensional prefactor - so that overall dimension remains to be 4 ?
Yes, that is what I said. This prefactor is typically assumed to be a power of the scale of the new physics related to the effective operator.
thanks alot
FAQ: Dimension of terms in Lagrangian
What is the dimension of the Lagrangian in classical mechanics?
In classical mechanics, the dimension of the Lagrangian, which is typically represented as L, is the same as the dimension of energy. Therefore, it has the dimension of mass times length squared per time squared (ML²/T²).
How do you determine the dimension of a term in the Lagrangian?
To determine the dimension of a term in the Lagrangian, you need to ensure that each term has the same dimension as energy (ML²/T²). This involves analyzing the dimensions of each variable and constant in the term, such as mass (M), length (L), and time (T), and combining them appropriately.
Why must all terms in the Lagrangian have the same dimension?
All terms in the Lagrangian must have the same dimension to ensure the consistency and physical meaningfulness of the equations of motion derived from it. This requirement stems from the principle of dimensional homogeneity, which states that equations must be dimensionally consistent.
What is the dimension of the Lagrangian density in field theory?
In field theory, the Lagrangian density, often denoted as ℒ, has the dimension of energy per unit volume. Therefore, its dimension is ML⁻¹T⁻², which is energy (ML²/T²) divided by volume (L³).
How do the dimensions of fields affect the dimension of the Lagrangian?
The dimensions of fields play a crucial role in determining the dimension of the Lagrangian. For instance, in a scalar field theory, the field itself must have a specific dimension to ensure that the Lagrangian density has the correct dimension. Typically, the dimension of the field is chosen such that when combined with derivatives (which have dimensions of L⁻¹) and other constants, the resulting term has the dimension of energy density (ML⁻¹T⁻²).
