Diode Configs: Same Work | Rectify Me Please
  • Thread starter Thread starter debajyoti datta
    Diode Diodes
Two diode configurations, back-to-back and anti-parallel, are often confused but serve different purposes. Back-to-back diodes block current flow in both directions, while anti-parallel diodes allow current to flow in one direction, effectively rectifying the signal. Zener diodes can be connected back-to-back for voltage regulation in specific applications, such as double-sided clipping circuits. Rectifier diodes are also used in high-frequency switch-mode power supplies (SMPS) in a back-to-back configuration. Understanding the context of each configuration is crucial for their correct application.
debajyoti datta
2 diodes connected back to back ...and 2 anti-parallel diodes...are these 2 configurations same...i mean work similarly?...i think NO...rectify me please if wrong...it might be a silly question but i would really appreciate the answer
So that whichever way current tries to flow, there will always be one diode which blocks the current? Draw it and try it.
in back to back connected diodes...current will never flow...right?
Yes, that is so.
Yet there may be times when you do see a pair of diodes ("Zener diodes") connected exactly like that: back-to-back. What is this about?
Sir,i have seen that in double sided clipping circuits..so that output is between (Vz.+Vk) and - (Vz.+Vk)..actually my question arose from there
Likes NascentOxygen
Careful..never?...zener back to back make a voltage regulator
Rectifier diodes are sold back to back as a high frequency smps rectifer using the center point as the AC location, and signal diodes are connected back to back as a decision point (probably not the right term) but I see them all the time.
The latter two are 3 terminal circuits, so without context, the question could be misleading.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
