Direct loading of synchronous generator
In summary, the procedure for finding regulation of a synchronous generator by direct loading may vary depending on the source.
cnh1995
1,164
What is the exact procedure for finding regulation of a synchronous generator by direct loading? We have it in our syllabus..For full load,I know the initial steps till the rated voltage is obtained at rated speed on no load. But when the load is switched on, my book says:
1.Terminal voltage reduces, so it is brought back to rated value by changing excitation.
2. Speed reduces, so it is brought back to rated value by speeding up the prime mover.
3. Then the load is thrown off and further procedure is done.
But in some books, step 2 is omitted. What is the right way?
It sounds like you are connecting the synchronous generator to a local load, not to the power grid.
When serving a local load, voltage, speed and frequency may not be very important. If so, then either or both of steps 1 and 2 might be skipped.
The "natural" environment for a synchronous generator is connected to the grid, not to a local load. There is no reason to select a synchronous generator rather than an induction generator to serve a purely local load. I object to the educational practice of teaching synchronous generators labs with local loads.
Yes, its connected to local load in our lab. But why voltage, frequency and speed are not important for local loads?
Also, due to the local load, alternator slows down. But what will happen if it were connected to the grid instead? It won't slow down, right?
Importance is determined by the load. A resistive load is insensitive to frequency. Also, most real life loads are designed for nominal voltage +- 10%. Inside that range, they don't care about voltage.
If you connect a synchronous generator to the grid, it's frequency becomes grid frequency exactly. That is why we use the word synchronous. It must be "syncronized" with the grid. The real power flow may be plus or minus, making the machine a generator or motor, depending on the mechanical power on the shaft.
If you raise/lower the voltage while connected to the grid, the reactive VAR flow increases/decreases changing the power factor. That may be good or bad, depending on what the grid needs.
Good luck with your studies.
Related to Direct loading of synchronous generator
What is direct loading of synchronous generator?
Direct loading of synchronous generator is a method of using the generator's output directly without any intermediate devices or energy storage systems. This allows for efficient and reliable power generation.
How does direct loading of synchronous generator work?
In direct loading, the generator is connected directly to the load, which could be a mechanical device or an electrical system. The generator's output voltage and frequency are controlled by adjusting the speed of the rotor, which is connected to a prime mover such as a turbine or an engine.
What are the advantages of direct loading of synchronous generator?
Direct loading eliminates the need for complex and expensive power conversion systems, making it a cost-effective solution. It also increases the overall efficiency of the power generation process and reduces the risk of system failures due to fewer components.
What are the limitations of direct loading of synchronous generator?
Direct loading may not be suitable for all types of loads, as the generator's output voltage and frequency are directly affected by the speed of the rotor. This may lead to voltage and frequency fluctuations, which can be problematic for sensitive electronic equipment.
How is direct loading of synchronous generator different from indirect loading?
In indirect loading, the generator's output is first converted to a different voltage or frequency before being supplied to the load. This requires additional power conversion systems, making it a more complex and costly solution compared to direct loading.
  • Electrical Engineering
