Direction of friction between disks
The discussion centers on determining the direction of friction between two disks, D and E, where disk D rotates clockwise and disk E is initially at rest. The confusion arises regarding the frictional force's direction, with the correct understanding being that friction acts to oppose the relative motion between the disks. When analyzing disk D, the friction force points left to counter its clockwise motion, while for disk E, the friction force points right as it accelerates to match disk D's velocity. Clarification of these forces is essential for solving the problem accurately. Understanding the interaction between the disks is crucial for determining the time required for disk E to reach the same angular velocity as disk D.
edsoneicc
Disk D turns with a constant clockwise angular
velocity of 30 . Disk E has a weight of 60 lb and is
initially at rest when it is brought into contact with D.
Determine the time required for disk E to attain the same
angular velocity as disk D. The coefficient of kinetic
friction between the two disks is 0.3 . Neglect the
weight of bar BC.
2. Relevant equation
Summation of forces and moments.
I am confused with the direction of friction. In my calculations, the friction points to the left because the velocity where the disk meets points to the right; which resulted to a wrong answer. However, the correct free body diagram is shown above.
That is the force that "what" exerts on "what else?" And what is the reaction force to that?
So when I isolate disk D, the friction points to the left to counter the clockwise motion, and when I isolate disk E, it now points to the right. Is this right?
Yes.
Likes edsoneicc
Thanks!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
