Direction of induced EMF in loop
The discussion centers on determining the direction of induced electromotive force (emf) in a loop based on Faraday's and Lenz's laws. The current in the wire is increasing upwards, leading to a magnetic field directed into the page, which should induce a counteracting magnetic field out of the page. This would suggest a counter-clockwise induced emf according to the Right-Hand Rule. However, the original conclusion is questioned, prompting a reevaluation of the statements made. The conversation also touches on a misunderstanding regarding the behavior of a sine function, which is clarified.
iharuyuki
Faraday's and Lenz' law.
emf = -d(ф)/dt
The current is increasing upwards during that time interval.
Thus, by Right-Hand-Rule, the magnetic field goes into the page at the loop.
Lenz' law says that the loop's induced emf will produce a magnetic field that opposes the field from the wire.
Thus a magnetic field in the opposite direction, out of page, would mean, by RHR, that the induced emf is counter-clockwise.
This is however not the answer. Which one of the above statements is flawed?
Thank you very much.
Draw the graph of sin2πt and check if it increases from 0.25 to 0.3
Oh I understand that it decreases actually. I had only punched sin (2pi(0.28)) into a calculator and it gave me a positive. Thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
