Directivity index of an underwater acoustic transducer array
  • Thread starter Thread starter Akshathkrs
The discussion centers on calculating the directivity index of an underwater acoustic transducer array using half power beamwidths in both azimuth and elevation planes. Participants suggest that reviewing existing literature and sharing specific findings can help clarify the calculation process. There is also a recommendation to consider parallels with RF antenna arrays, as the mathematical principles may be similar. Engaging with relevant resources and asking targeted questions is encouraged to deepen understanding. Overall, the conversation emphasizes the importance of research and specific inquiries in solving the problem.
Akshathkrs
Is there a relation or formula to calculate directivity index of an underwater acoustic transducer array, given the half power beamwidths of the array in azimuth and elevation planes.
Welcome to PF.
What have you found so far in your reading? Can you post some links to your reading and ask specific questions about that reading? That's probably the best way to get you started on this question.
Also, do you have any experience with RF antenna arrays? Some of the math will be similar.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
