MHB Discontinuity: Jump discontinuity
Jump discontinuity occurs when the left-hand limit and right-hand limit of a function at a specific point are not equal. The functions discussed, f(x) and g(x), illustrate this concept, with f being continuous and g exhibiting a jump discontinuity at x=1. While piecewise functions commonly have jump discontinuities, other functions like the Heaviside step function also demonstrate this behavior. The discussion clarifies that jumps in discontinuities are not strictly vertical in a mathematical sense, but can be visualized as abrupt changes in the graph. Understanding limits at each point of a function is essential for identifying jump discontinuities.
samir
I earlier posted about point discontinuity. It became overwhelming pretty quickly. Now I would like to focus this thread at jump discontinuity specifically, if you don't mind me posting multiple threads about discontinuity.
From what I understand, "jump discontinuity" occurs where the left-hand limit and right-hand limit for a given are not equal. Correct?
Assume we have the following functions.
$$f(x)=\begin{cases}x^2, & x\leq 1 \\ 2-x, & x\gt 1\end{cases}$$
$$g(x)=\begin{cases}x^2, & x\leq 1 \\ 6-x, & x\gt 1\end{cases}$$
Function $f$ is continuous, but function $g$ is discontinuous. Correct?
$$\lim_{{x}\to{1^{-}}}f(x)=1$$
$$\lim_{{x}\to{1^{+}}}f(x)=5$$
$$\lim_{{x}\to{1^{-}}}f(x) \neq \lim_{{x}\to{1^{+}}}f(x)$$
$$\lim_{{x}\to{1^{-}}}g(x)=1$$
$$\lim_{{x}\to{1^{+}}}g(x)=1$$
$$\lim_{{x}\to{1^{-}}}g(x) = \lim_{{x}\to{1^{+}}}g(x)$$
So far so good? If we were to examine the limits of a function in this manner for every point, we would be able to tell if it has any jump discontinuities?
Now, do only piece-wise functions have jump discontinuities? Are there any other kind of functions that have "jump" discontinuities?
Does the jump always occur in the vertical direction? As in jumping from $(1,1)$ to $(1,5)$ as opposed to $(1,1)$ to $(2,4)$?
Mathematics news on Phys.org
Hey samir! ;)
So far so good... just that $f$ and $g$ seem to have been mixed up.
And yes, examining the limits of each point of a function will tell us where the jump discontinuities are.
Which functions are you considering?
If we only look at standard continuous functions like $\sin x$, and at functions we compose with nested function calls and additions and such, we can't get jump discontinuities.
However, consider the standard unit step function, written as $H(x)$ or $u(x)$ or $\Theta(x)$, which is also known as the Heaviside step function.
It implicitly has a jump discontinuity.
Of course, to define what we mean with $\Theta(x)$, we'll need a piece-wise function definition. :rolleyes:
Anyway, we can write your $g(x)$ as:
$$g(x) = x^2\Theta(1-x) + (6-x)\Theta(x-1)$$
The actual value of $\Theta(0)$ is a bit ambiguous though, and depends on which text you're reading.
It can be any of $0$, $\frac 12$, or $1$. If you consider it relevant, we should simply define what we mean by $\Theta$ before using it.
(For the record, I picked $\Theta$ as symbol to use, because it's the most exotic. :cool:)
We don't really have a "vertical" jump in a function - a function is supposed to be an abstract thing without geometrical meaning.
However, if we get a pencil and draw a graph of $y=f(x)$ where $y$ is considered to be vertical on the paper, then yes, a jump discontinuity corresponds to an abrupt change in $y$ from one $x$ value to the next - a vertical jump.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
