Discovering Pascal's Principle: Solving Hydraulic Press Problems | Homework Help
The discussion focuses on solving problems related to Pascal's Principle in a hydraulic press setup. The main equations used are based on the relationship F_1A_1=F_2A_2, allowing the calculation of forces exerted by pistons of different sizes. A specific example involves determining the force required on a smaller piston to balance a 20.0 kN force on a larger piston with diameters of 3.80 cm and 53.0 cm. The calculations provided indicate a miscalculation in unit conversion, suggesting the answer should be in kN rather than N. Overall, the thread emphasizes the importance of unit accuracy in hydraulic system problems.
jinman
[SOLVED] Pascal's Principle help.
A piston of cross-sectional area a is used in a hydraulic press to exert a small force magnitude f on the enclosed liquid. A connecting pipe leads to a larger piston of cross-sectional area A.
1. What force magnitude F(2) will the larger piston sustain without moving?
2.If the piston diameters are 3.80cm and 53.0cm, what force magnitude on the small piston will balance a 20.0kN force on the large piston?
F_1A_1=F_2A_2
For a i just solved the equation for F_2. so (F_1*A_1)/A_2=F_2
For B i plugged in my numbers where>>> F_2=(20.0kN*pi*.019^2)/pi*.265^2
F_2=1.03*10^2N?
Any help?
Your method looks good to me. Your not getting the right answer?
Check your units. With the units you used there, the answer your getting should be coming out in kN, not N.
thanks!
Anytime.:smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
