B Discovering the Mystery Behind the Direction of Water Swirl in Your Sink
  • B
  • Thread starter Thread starter tomlib
    Water
The direction of water swirl in sinks is influenced more by initial conditions than by the Earth's rotation. While the Coriolis effect theoretically affects large-scale phenomena, it is typically overshadowed by factors like pre-existing water motion. Personal experiments, such as filling and emptying sinks, can reveal varying swirl directions based on these disturbances. Videos from channels like Veritasium and Smarter Every Day explore this topic further. Ultimately, the initial state of the water is the primary determinant of its swirling direction.
tomlib
I have a trivial question. What causes the direction in which the water in the spout turns? They say it's according to the Earth's hemisphere, but I don't really believe it and I'm looking for other reasons. Finally, even this reason would have to have some explanation.
So, there is a theoretical effect due to the rotation of the earth. However, usually that is swamped by other disturbances like the initial state. So if there is only the slightest rotation already in the water before you start draining that will easily decide the rotational direction. Veritasium and Smarter Every Day did a video on this:
Likes russ_watters and berkeman
Did you fill and empty the sinks in your house to see which way they swirl? What did you learn?
That I blocked the drain with a match.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
