Discovery of silicon & how is it extracted commercially
  • Thread starter Thread starter EmuWizard
    Discovery Silicon
Silicon was first identified by Lavoisier in 1787, but Berzelius is credited with its isolation in 1823. The commercial extraction of silicon involves heating silicon dioxide (SiO2) with coke in a blast furnace to remove impurities. Conducting a small-scale experiment at home is challenging due to the high temperatures required for SiO2 reduction. The discussion highlights that chemists historically aimed to decompose substances into simpler elements, driven by curiosity. For a report specifically on silicon, a focus on its extraction methods and historical context is essential.
EmuWizard
what lead to the discovery of silicon
how is it extracted commercially & how can it be done at home aswell?
Our usual rates for doing other people homework start at $100/hour. But once you will show what you did by yourself and where you get stuck, we will push you in the right direction for free.
sry for bieng so blunt & so naive :p
i got this much so far. It was only identified in 1787 by a scientist Lavoisier. However, Berzelius was the first person to isolate silicon in 1823, and thus he is credited with its discovery (web1.caryacademy.org). the thing is i can't find out why he was doing what he was doing, i can't find anyinfo on that.
& i found my info about how it is extracted commercially, apparently they take out the impurities by heeting it with coke in a blast furnace. but i need a small scale experiment too which i can't find. i can only think of mixing it with sumthing to react with the oxygen & leave wat i need behind.
I am not sure if I understand the first question, as the only answer I am aware of is "curiosity". What I mean is that chemists were trying at the time to decompose every substance into what they called "simple substances" - what we today know as elements (note: don't treat nomenclature I am using too seriously, as I am translating from Polish). Berzelius was the first one to succeed in preparing pure silicon, but I don't remember reading about any special events that lead to that discovery.
Small scale & home experiment looks unlikely to me, you need high temperatures for SiO2 reduction. Does it have to be production of Si, or something else where Si compounds are involved will do as well?
lol that's good enough answer for me aswell.
& yes it has to specificcally be Silicon, as I am doing a report on it.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
