- #36
Clever Penguin
- 74
- 20
I hope we find out what the core is made of. ![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm not sure if the actual material will be determined however I believe the main focus there is determining whether or not it's solid. I'll look into that and see what they are expecting to find.Clever Penguin said:I hope we find out what the core is made of.![]()
I've asked the folks at JPL in an email which I may or may not get a response to, I'll keep you posted if a response is forthcoming. The only information readily available is the line about uploading commands for the insertion maneuvers about a week before arrival. It could be that the actual navigation to Jupiter has become so routine that JPL doesn't take time to mention the details, all I see so far is the mention of certain "deep space maneuvers. One things for certain they are getting very good at ending up in the "right place at the right time"D H said:how does Juno navigate
See page 4 of this briefing by the Software Engineering Institute, who apparently were validating parts of the Juno flight software. It's "export controlled and proprietary." JPL used to be much more open in the past. If they had their druthers, I suspect they would now classify [itex]\mathbf F=m\mathbf a[/itex] as Secret//NOFORN.rootone said:I'm not sure if there is any secrecy, why would there be?
That's correct. We should expect to see some stuff after the closest approach (perijove) on August 27, but then not much until November 2. All scientific instrumentation will be turned off for the October 20th closest approach, just as it was for orbit insertion. Patience is a virtue here. The science starts in early November.1oldman2 said:I believe things will be a little slow while Juno completes the first two orbits.
I'm not finding that info anywhere yet, but will watch and post if I do. I have read the close aspect of the orbit is actually very brief, in the neighborhood of two hours each time so that would make the speed very high considering how much real estate they are covering.The Bill said:Approximately what will Juno's orbital speed be at periapsis of its science orbits?
As far as I can tell JPL plans to be gathering data constantly while in the science orbit phase. While in the "capture orbits' all unnecessary equipment is shut down to free up processing power in case of a glitch, no cam or anything running that is not vital to the control of Juno, thus no imaging or any experiments until science orbits begin, aside from a couple of instrument check outs to make sure the science equipment is functioning normally, no "cam" images are expected until early November. This site is one of the best I've found for mainstream info and are worth bookmarking for the duration of the project. http://www.planetary.org/dragoneyes001 said:37 orbits at about 23 days each how much time will they be active in close orbit? 1-2 days per? what's surprising me is the lack of a new planetary pic from the first close pass from Jul 4th everything I've seen so far are renderings.
Very cool,Dotini said:I found this interesting tidbit on todays's edition of spaceweather.com. Jupiter's magnetosphere and moons have some amazing properties to be explored. Let's get going.
About 56 km/s to 57 km/s. This does not take into account Jupiter's rapid rotation rate (12.6 km/s at the equator) or Jupiter's large equatorial bulge.The Bill said:Approximately what will Juno's orbital speed be at periapsis of its science orbits?
The science phase orbits will be 13.965 days long, not 23 days long. That period allows the NASA Goldstone DSN complex to receive data from each and every one of the closest approaches.dragoneyes001 said:37 orbits at about 23 days each how much time will they be active in close orbit? 1-2 days per? what's surprising me is the lack of a new planetary pic from the first close pass from Jul 4th everything I've seen so far are renderings.
13.6 days then how is it 37 orbits in that total length of time what I was seeing in the orbit simulation was mostly identical orbits with changing angles in relation to the planet i have to have missed somethingD H said:About 56 km/s to 57 km/s. This does not take into account Jupiter's rapid rotation rate (12.6 km/s at the equator) or Jupiter's large equatorial bulge.
Different orbits will have slightly different periapsis distances, by design, from 4200 to 7900 km above the cloud tops. These values, combined with Jupiter's 71492 km equatorial radius, Jupiter's 126686534 km^3/s^2 standard gravitational parameter, and the orbital period of 13.965 days, Kepler's third law, and the vis viva equation yield the above range of periapsis velocities.
There was no science return from the orbit insertion operation because all of the scientific instruments, including JunoCam, were powered off during that extremely critical operation. All of the electrical power and all of the computing power of the spacecraft were dedicated to one task during orbit insertion, and that one task was of course orbit insertion.
http://whqr.org/post/star-trackers-help-juno-find-its-wayD H said:This is not meant to be a dig at you, 1oldman2. It is a dig at JPL, Lockheed Martin, and SWRI.
There is no meat in that link. There is no meat, anywhere, on any of the web pages that describe Juno. It's all fluff, no substance. Compare that to the incredible technical details released with regard to the New Horizons mission to Pluto or the Rosetta mission to Churyumov-Gerasimenko. At a $1.1 billion dollar price tag, answering how does Juno navigate should not be hidden in secrecy. I have looked. There is no answer to that question.
How exactly does this 'Deep Space Network' determine the position of Juno? Could someone please try to explain this to me?"To find the position when you go to deep space, like on Juno, you need to have help," says Jørgensen.
These days the help comes from NASA's Deep Space Network — three large radio antennas in California, Australia and Spain. They receive radio signals from Juno and use those to figure out where the probe is and how fast it's moving.
"That works beautifully for deep space spacecraft ," says Jørgensen. "It's just that it is relatively expensive to track with a big dish antenna, so people have been looking for different ways of navigating, and that's a problem you also can solve with the star tracker."
I guess something like conventional triangulation, (the scopes are located at different positions on Earth).Hoophy said:How exactly does this 'Deep Space Network' determine the position of Juno? Could someone please try to explain this to me?
The first two orbits are "capture orbits" each having a duration of 53.4 days, this is followed by the science orbits with the roughly 14 day duration.dragoneyes001 said:13.6 days then how is it 37 orbits in that total length of time what I was seeing in the orbit simulation was mostly identical orbits with changing angles in relation to the planet i have to have missed something
1oldman2 said:The first two orbits are "capture orbits" each having a duration of 53.4 days, this is followed by the science orbits with the roughly 14 day duration.
https://www.missionjuno.swri.edu/ne...t-team-begins-powering-up-science-instruments
1oldman2 said:(SNIP) And from http://www.jpl.nasa.gov/spaceimages/details.php?id=PIA20178
(SNIP)
I haven't noticed any Juno studies on this, any thoughts?
Same here, I don't even know how one would detect it, just thought I'd mention the theory.Clever Penguin said:I haven't noticed any Juno experiment designed to look for dark matter.
1oldman2 said:Same here, I don't even know how one would detect it, just thought I'd mention the theory.
From my experience of the Dawn mission photographing Ceres, my guess is no.dragoneyes001 said:like the first pic from juno just one question being out in space without any light wouldn't the star field be super visible in the background?
OmCheeto said:From my experience of the Dawn mission photographing Ceres, my guess is no.
The only time I remember seeing stars was from a composite image.
Good question though.
I asked the same thing last year about Ceres, and got the following response:
June 4, 2015
Marc Rayman, director and chief engineer for NASA's Dawn mission; "... For the approach phase images, we used two different camera integration times (what most people call exposure times). One value was chosen to ensure Ceres was correctly exposed and the other was chosen to bring out the background stars. The images alternate, so we interpolate to get Ceres' location relative to stars. ..."
[ref: PF]
Ah ha! Just found the explanation of the image I was referring to.
But, I'm afraid I'm not much of an astronomer, so I don't quite understand how "apparent magnitude" works.
Does Jupiter get brighter as you get closer?
Anyways, here's a list of the "apparent magnitude" of Jupiter and the 4 brightest stars:
Jupiter at brightest: -2.7
Sirius: -1.46
Canopus: -0.72
Rigil Kentaurus: -0.27
Arcturus: -0.04
My guess is, that Sirius would probably show up, if the camera were pointed in the right direction.
Hi Om, Marc pretty well described what's going on in the paragraph quoted from your link,OmCheeto said:From my experience of the Dawn mission photographing Ceres, my guess is no.
Yes, it does. That's the reason for using apparent magnitude as opposed to absolute magnitude. Absolute magnitude does not change with distance. Apparent magnitude does change with distance, in an inverse square manner.OmCheeto said:But, I'm afraid I'm not much of an astronomer, so I don't quite understand how "apparent magnitude" works.
