Displacement of a particle moving on the xy axis?
The discussion focuses on calculating the displacement of an electron moving along the x-axis under constant acceleration in both x and y directions. Given the initial velocity and acceleration values, the time taken for the electron to travel a distance of 0.0100 m is determined to be approximately 5.67458 × 10^-10 seconds. The next step involves using this time to find the y-coordinate of the electron, utilizing the known acceleration in the y-direction. Participants suggest using the same kinematic equations applied for the x-direction to solve for the y-coordinate. The conversation emphasizes the importance of correctly applying the equations of motion to find the final displacement.
JessicaJ283782
As an example of the manipulation of an electron beam, consider an electron traveling away from the origin along the x-axis in the xy plane with initial velocity vi= vii. As it passes through the region x = 0 to x = d, the electron experiences acceleration a = axi + ayj, where ax and ay are constants. For the case vi = 1.74 ✕ 10^7 m/s, ax = 7.84 ✕ 10^14 m/s2, and ay = 1.51 ✕ 10^15 m/s2, determine the following, at x = d = 0.0100 m.
(a) the position of the electron (yf=?)So, I went through, and I used the equation d=vi*t+.5(at^2)
I plugged in: .01=1.74*10^7t+.5(7.84*10^14)t^2
I got the time to be 5.67458*10^-10
Now, I know you have to plug the time into an equation, along with the acceleration of y, but I am confused on which equation to use since you only know acceleration and time for the y coordinates?(b) the velocity of the electron
So, I used: vf=vi+at
vf(x)=5.67458*10^-10 X 7.84*10^14
and wouldn't you do the same for the y coordinates?
Thank you!
a)
So at this point in time, you now need to find the y-coordinate of the electron. You know the acceleration in the y-direction. Can't you find an equations, which you could then use? Perhaps the very same equation, you just used to find the time, just with different parameters?
Actually you know the velocity of the electron in the y-direction it is 0 m/s, therefore v=1.74*10^7i+0j m/s
and a=7.84*10^14i+1.5*10^15j, you have solved for t and you know vi and ai so you can solve for y. You are almost there.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
15K
