Displacement of a traveling wave
  • Thread starter Thread starter agadag
    Displacement Wave
The wave described by the equation y = 0.13 sin(t - 3.82x) is traveling in the +x direction. To find the displacement y at t = 26.5 seconds and x = 6.4 meters, one must substitute these values into the equation. The process involves basic arithmetic rather than complex physics concepts. The discussion highlights a lack of understanding of wave mechanics and a need for clearer instructional resources. Overall, the focus is on solving for wave displacement using given parameters.
agadag
The displacement (in meters) of a wave is y = 0.13 sin(t - 3.82x), where t is in seconds and X is in meters.
(a) Is this wave traveling in the +x or -x direction?
1.+x direction.
2.-x direction
(b) What is the displacement y when t = 26.5 s and x = 6.4 m?
The solution for part a is positive x direction
I cannot figure out how to do this problem at all. Professor did not cover this material and I have no background knowledge in vibrations or waves. I have been reading the chapter in the book, but it doesn't make any sense and doesn't have any equations. I'd really appreciate a good teacher right now. :)
I don't see any physics in this question! It is just some arithmetic work. You must substitute t = 26.5 s and x = 6.4 m into the equation
and find the value of y.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
