Displacement of ball bearing using conservation of energy
The discussion centers on the mechanics of a pendulum system involving a ball bearing released from a height. The final horizontal displacement (D) of the ball after release is derived from the equation D^2 = 4hL, which relates the initial height (h) and the vertical drop (L). Participants explore the conservation of energy principles, noting that potential energy converts to kinetic energy as the ball falls. The importance of time in the horizontal motion is highlighted, as a longer vertical drop allows for greater horizontal displacement due to the time spent in the air. Ultimately, the relationship between height, drop distance, and horizontal motion is clarified through this analysis.
phosgene
A large ball bearing is suspended as a pendulum. One end of the pendulum is held by the electromagnet (1) and the ball is initially held by magnet (2) at some height, h, above its lowest position. The ball is released from (2) and as the pendulum swings through the vertical, the ball cuts an infrared beam (3) and causes the electromagnet holding the string (1) to release it. Ideally, the string is released at the instant the ball cuts the infrared beam. The ball then falls a height L and travels a horizontal distance D from the point of release.
The final displacement (D) of the ball from the release point can be determined using:
D^2=4hL
I can't figure out how this was derived.
Potential energy = mgh
Kinetic energy = \frac{1}{2}mv^2
I really have no idea. I thought that the final displacement from the release point would be dependent only on h, as the force of gravity after release is only acting downwards, so the horizontal velocity wouldn't change. I've also tried 'reverse-engineering' the equation to figure out how it was derived, but I don't understand where the L*h value came from, as the final kinetic energy should be mg(L+h).
The velocity of the ball is horizontal at point 3 and you get it from conservation of energy. mgh=1/2 m v^2. After reaching point 3, the ball is a projectile.
ehild
Try the solution in two steps.
a) falling through h
b) falling through L.
Ok, horizontal velocity doesn't depend on L, but what if L is very big, let's say 1 mile ?
The ball takes "a lot of" time before touching the ground and during that time it moves horizontally as well.
Yes it does..So where's the problem?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
