Dissolving caffeine in room temperature water
Dissolving caffeine in water can be challenging, especially when attempting to mix 500mg in 10ml, as it often turns into a paste upon cooling. Heating the water initially helps, but the caffeine reverts to a paste as the solution cools. To improve solubility, using carbonated water is suggested, as its acidity can help ionize caffeine and enhance its solubility. Additionally, researching the solubility of caffeine at different temperatures may provide further insights. Exploring these methods can lead to a more successful dissolution of caffeine in water.
gregor_rdt
Hello everyone,
I have been trying to dissolve caffeine in water for a few days now.
I am trying to dissolve approx. 500mg of caffeine in approx. 10ml of water, but I am encountering the problem that the solution turns into a paste. If I heat the water beforehand, the caffeine dissolves well at first, but then quickly turns back into a paste as soon as the solution cools down.
Are there any processes or substances that improve the solubility of caffeine in water?
I look forward to any answers. :)
Chemistry news on Phys.org
Have you tried directly searching for an answer? Such as search terms increasing solubility of caffeine in water? After, of course, finding the solubility of caffeine in water as a function of temperature.
At PF, we want to help you find answers after you have made your own attempt.
try using a carbonated water. It is acidic and will cause the basic caffeine to ionize and increase its solubility in water.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
