Distance After Release- Problem on Forces
In summary, Block A will drop 11 meters while Block B will only drop 49.5 meters due to the coefficient of friction.
haengbon
38
In figure A, the coefficient of friction between block A and the tabletop is 0.3, Mass of block A= 30 kg, Mass of block B=20 kg. How far will block B drop in the first 3 s after the system is released from rest?
here is the figure :D
http://img137.imageshack.us/img137/5771/imagenz.png
*we use gravity= 10 (not 9.8 )
w (weight)
Nf (normal force)
ΣF (semation of forces)
f (friction)
T (tension)
BLOCK A
ΣFy= 0
-w + NF = 0
Therefore w = NF
W= mg
= 30 (10)
= 300 N
Therefore NF = 300 N
f= μNF
= 0.3 (300 N)
f= 90 N
ΣFx= ma
-f + T = ma
-90 + T = ma
-90 + T= 30 (a)
T= 90 + 30a
BLOCK B
W=mg
W=20 (10)
W= 200 N
ΣFy= ma
T-w=ma
T- 200 N = 20a
T= 200+20a
T=T
90+30a = 200 + 20a
90- 200 = 20a – 30a
-110 = -10a
-10 -10
a= 11 m/s^2
y= Vo + Voyt + at^2/2
y= 0 + 0 + 11 (3) 2 /2
y = 49.5 m
I got 49.5 but my professor said it was wrong :(can someone tell me where I went wrong? and what IS the correct answer?
haengbon said:
BLOCK B
W=mg
W=20 (10)
W= 200 N
ΣFy= ma
T-w=ma
T- 200 N = 20a
T= 200+20a
You made a sign error in setting up your Fy equation. You need to be consistent in your use of "a" for acceleration. If mass A moves to the right, mass B moves down. Thus if the acceleration of mass A is "a", then the acceleration of mass B is "-a".
T=T
90+30a = 200 + 20a
90- 200 = 20a – 30a
-110 = -10a
-10 -10
a= 11 m/s^2
Note how your acceleration is greater than gravity! That can't be right. :wink:
Just fix that equation for block B above and you'll be fine.
Oh o_O so the only mistake I made was not making the acceleration of block B negative? :D so if I changed it to negative, then it'll make all the difference ^^? I asked through yahoo answers too and one replied that the answer was 9.7 m :D is it most likely correct? I couldn't understand his explanation that well that's why I'm still confused -__-
Yes. Try it and see. Correct the equation as I indicated; find the correct acceleration; then use it to find the distance traveled.
BLOCK B
W=mg
W=20 (10)
W= 200 N
ΣFy= ma
T-w=ma
T- 200 N = 20a
T= 200+20a
So I tried doing it like this...
T-w=m(-a)
T- 200 N = 20(-a)
T= 200+20(-a)
Is this correct?
T-w=m(-a)
T- 200 N = 20(-a)
T= 200+20(-a)
Is this correct?
So far, so good.
Doc Al said:
So far, so good.
So this is the result right? :D
T=T
90+30a = 200 + 20(-a)
90- 200 = 20(-a) – 30a
so from what I can understand... 20(-a) becomes -20a right ? :D or is it wrong?
so...
90- 200 = -20a – 30a
-110 = -50a
-50 -50
a= 2.2 m/s^2 ? :D
haengbon said:
a= 2.2 m/s^2 ?
Looks good to me.
thank you thank you thank you so much! I got the correct answer! xDD thank you for being so patient :)
FAQ: Distance After Release- Problem on Forces
How does the distance after release in a problem on forces affect the overall outcome?
The distance after release is an important factor in determining the overall outcome in a problem on forces. It is the distance that an object travels after being released from a force and can greatly impact its final position and speed.
What forces contribute to the distance after release in a problem on forces?
There are many forces that can contribute to the distance after release in a problem on forces. Some common forces include gravity, friction, air resistance, and applied forces. Each force can affect the distance an object travels differently.
How can the distance after release be calculated in a problem on forces?
The distance after release can be calculated using the formula d = ut + 1/2at^2, where d is the distance, u is the initial velocity, a is the acceleration, and t is the time. This formula can be applied to calculate the distance after release in various scenarios.
Does the shape or weight of an object affect the distance after release in a problem on forces?
The shape and weight of an object can certainly affect the distance after release in a problem on forces. Objects with a larger surface area or greater weight may experience more air resistance or friction, causing them to travel a shorter distance after release compared to smaller or lighter objects.
Can the distance after release be altered by changing the forces acting on an object?
Yes, the distance after release can be altered by changing the forces acting on an object. By increasing or decreasing the applied force, for example, the object may travel a greater or shorter distance after release. Additionally, changing the direction or magnitude of forces like friction or air resistance can also impact the distance an object travels after release.
