Distance/displacement integration problem
  • Thread starter Thread starter zachem62
    Integration
zachem62
Suppose that v(t)=t2 -2t -8, 1≤t≤6 is the velocity function (in meters per second) of a particle moving along a line. Find a) the displacement and b) the distance traveled by the particle during the given time interval.
so i integrated the velocity function at the interval 1 to 6 and got the answer (-10/3)m. so i have no idea if this is the distance or displacement and if it is one of those, then how would i find the other one?
thanks!
thanks!
Think about whether the particle can change its direction of travel between times 0 and 6, and if it can, think about what the integral ∫v(t): t=0..6 actually computes.
RGV
RGV
in the question it says that t can only be between 1 and 6 so i can't use any 0. and it is possible that the particle can change direction and my guess is this means that the integral ∫v(t): t=1 to 6 computes the distance. am i right?
then how would i get displacement? can u give me a hint? i know that its the final position minus initial position but i don't know if I'm supposed to get it by integrating the function or do something else.
v(t)=t^2 -2t -8, 1≤t≤6
When t= 6, v(6)= 36- 12- 8= 16.
When t= 1, v(1)= 1- 2- 8= -11.
Now, what was the displacement? (Do you know what "displacement" means?)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
