Distance of particle travels from origin, and maximum speed, picture included
The discussion revolves around a physics problem involving a 3.2 kg particle influenced by a potential energy function, with a total energy of 18 J. Participants emphasize the conservation of mechanical energy, noting that the total mechanical energy consists of kinetic and potential energy. The potential energy function is given as U = a|x|, leading to questions about how to calculate the particle's kinetic energy without knowing its velocity. Clarification is sought on distinguishing between initial and final potential energy states. The conversation highlights the importance of understanding energy conservation principles in solving the problem.
gap0063
A 3.2 kg particle moves along the direction
under the influence of a force described by the
potential energy function U = a k~xk, where
a = 5.48 J/m and x is the position of the
particle in meters measured from the origin
as in Figure.
The total energy of the particle is 18 J.
[PLAIN]http://img828.imageshack.us/img828/2877/problem9.jpg
(a) Determine the magnitude of the distance
that the particle travels from the origin before
reversing direction.
Answer in units of m.
(b)Find the maximum speed of the particle.
Answer in units of m/s.
Not sure
the only equation I know with distance is \DeltaEmech=-fkd
So I know the total energy is 18 J
but there is no u
and there is no velocity...maybe i can turn acceleration into velocity?
The force is conservative as there is potential energy. In case of conservative forces, the total mechanical energy is conserved. You know the potential energy, U=α|x|. What other energy does the particle have?
ehild
ehild
it also has kinetic energy?
so Ki+Ui=Kf+Uf?
Yes!
ehild
ehild said:
Yes!
ehild
I'm still confused... what part is Uf and what part is Ui
and I don't know how to calculate kinetic energy without velocity
What is the PE at x=0?
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
