Distance traveled = Average velocity x time
In summary, the problem involves a car traveling with a constant speed of 80 km/h and a stationary motorcycle policeman who sets off in pursuit. After accelerating to 80 km/h in 10.0 s, the policeman reaches a constant speed of 100 km/h after an additional 5.0 s. The question is at what time will the policeman catch up with the car? To solve this problem, one must use the standard equations of motion and assume that the policeman's accelerations are constant. By finding the distance traveled by both the car and the policeman in 15 seconds, the distance between them can be determined. This distance can then be used to calculate the time it takes for the policeman to catch up with the car.
Voltman
A car traveling with a constant speed of 80 km/h passes a stationary motorcyle policeman. The policeman sets off in pursuit, accelerating to 80 km/h in 10.0 s and reaching a constant speed of 100km/h after a further 5.0 s. At what time will the policeman catch up with the car?
I am stuck in the above problem. I do not know what to do. Any help/complete working out solution in the above problem will be appreciated! Please provide hints for me to work this out.
Welcome to Physicsforums Voltman! We have a policy that we can not give help without at least some sort of minimal effort, as I'm sure you can understand why. There should have been a template given to you, you shouldn't have deleted it but rather filled it out, its quite useful actually!
I will try to give you some sort of a start. From the way the question was worded, let's assume that the accelerations of the policeman are constant. So in the first 10 seconds, what was his acceleration? How about in the next 5 seconds?
Are you familiar with the standard equations of motion? eg v=u + at. Using these equations, with our new knowledge of the accelerations for each part of the bikers motion so far, you can work out the distance the biker has traveled in these 15 seconds. Its also easy to work out the distance the car got as well, so we know the distance between them after 15 seconds, and their speeds. You can surely finish that problem.
The distance traveled = Average velocity x time.
Using this formula find the distance traveled by the policeman in 15 s.
During 15 s find the distance traveled by the car.
Find the distance between the car and policeman. Let it be x.
Now both are moving with constant velocity. After time t policeman catches the car. During this period car travels s distance and policeman travels s + x distance.
So (100km/h)/(s + x) = (80km/h)/s. Find s and then t.
Related to Distance traveled = Average velocity x time
1. What is the formula for calculating distance traveled?
The formula for calculating distance traveled is Distance traveled = Average velocity x time. This formula takes into account the average velocity of an object and the time it has been moving to determine the total distance traveled.
2. How is average velocity defined?
Average velocity is defined as the total displacement of an object divided by the total time it took to cover that displacement. It is a measure of the rate of change of position over time.
3. Can this formula be used for any type of motion?
Yes, this formula can be used for any type of motion as long as the average velocity and time are known. It is commonly used in physics and kinematics to calculate the distance traveled by an object.
4. What is the unit of measurement for distance traveled?
The unit of measurement for distance traveled is typically in meters (m) or kilometers (km), but it can also be expressed in other units such as feet (ft) or miles (mi) depending on the system of measurement used.
5. How does time affect the distance traveled?
Time plays a crucial role in determining the distance traveled. The longer an object is in motion, the further it will travel. This can be seen in the formula, as time is directly proportional to the distance traveled. In other words, the longer the time, the greater the distance traveled.
