Distance Travelled at Time t: Solve Velocity Problem w/ a=5, b=4, c=1
  • MHB
  • Thread starter dave dx
  • Tags
    Velocity
In summary: Many thanks for getting back to me. Alas I had gotten the root before and am not yet up to speed enough to understand why you've substituted "u" in?
dave dx
the velocity of an object is given by v=a+b exp(-ct)-2t
given the values of a, b and c below the distance travled at time t is...?
a=5 b=4 c=1
I have been banging my head against the wall for over a week over this. Any help or tips that can be given would be appreciated.
To find the distance $D$ traveled, we must use:
\(\displaystyle D(t)=\int_{t_i}^{t_f}\left|v(t)\right|\,dt\)
So, we need to find any roots of the given velocity function:
\(\displaystyle v(t)=5+4\exp(-t)-2t\)
We will need to use a numeric root finding technique (such as Newton-Raphson) to approximate the root(s). Using such a method, I find one root at:
\(\displaystyle t\approx2.6423828566319685138\)
So, if we call this root $r$ (and change the dummy variable of integration, letting $t_i=0,\,t_f=t$), we may write:
\(\displaystyle D(t)=\begin{cases}\displaystyle \int_0^t 5+4e^{-u}-2u\,du & t\le r \\[3pt] \displaystyle \int_0^r 5+4e^{-u}-2u\, du-\int_r^t 5+4e^{-u}-2u\,du, & r<t \\ \end{cases}\)
Can you proceed?
I have evaluated the equation from 0 to the root shown to the answer 9.94493 and aparantly this is incorrect. so I am obviosly still making mistakes somewhere.
Also i assume that the changing of 5 to a 4 was a typo? (Otherwise I have severally misunderstood the calculus that I have learned)
One final point, as I am also unsure on terminology/ layout of university level mathematics, I assume that your two final equations are presented as different ways to achieve the same answer and as such do not depend on one another?
I am sorry for the inconvenience but I am trying to learn a lot at a fast rate.
When evaluating definite integrals, the variable of integration is said to be a "dummy" because it gets "integrated out." It is considered bad form to have the same variable in the inner integral (integrand and differential) as in the limits, and so that's why I changed.
I used W|A and got $9.94496$, so you seem to have done it correctly. You are being asked for the general function I assume, and what you did was find the distance traveled up to the point at which the velocity is zero. So, what you did was correct, but not what the problem is actually asking.
W|A - integral of 5+4e^(-x)-2x from 0 to 2.6423828566319685138
Yes, that was a typo, which I have fixed...:eek:
The function I presented (in which you are to evaluate the given definite integrals) is a piecewise-defined function. Which piece you should use depends on the value of $t$. If $t\le r$, then you use the first piece, and if $r<t$, then you use the second part.
Asking questions here is NOT an inconvenience. Our (MHB's) primary reason for being is to help people with mathematics. :D
FAQ: Distance Travelled at Time t: Solve Velocity Problem w/ a=5, b=4, c=1
1. What is the equation for distance travelled at time t with the given values of a, b, and c?
The equation is d(t) = 2.5t^2 + 4t + 1.
2. How do you calculate the velocity at a specific time using the equation?
To calculate the velocity at a specific time t, you can take the derivative of the equation d(t) with respect to time, which gives you the velocity equation v(t) = 5t + 4.
3. Can this equation be used to find the distance travelled after a certain amount of time?
Yes, by plugging in a specific time t into the equation, you can find the distance travelled after that amount of time.
4. How do the values of a, b, and c affect the distance travelled at a specific time?
The value of a affects the overall shape of the curve, b affects the slope of the curve, and c affects the vertical shift of the curve. Together, these values determine the distance travelled at a specific time t.
5. Is this equation valid for all types of motion?
No, this equation is specifically for calculating distance travelled based on a constant acceleration of 5 units per second squared, initial velocity of 4 units per second, and initial displacement of 1 unit. Other types of motion may require different equations.
9K
