A Distribution of Range of Samples taken from N(0,1)
  • A
  • Thread starter Thread starter uart
The discussion centers on the distribution of the sample range from a standard normal distribution, N(0,1), and whether it has a specific name or is implemented in statistical software. The "Studentized Range" distribution, used for samples from a student_t distribution, is noted, but no equivalent is found for N(0,1). While it can be approximated using large degrees of freedom in existing functions like ptukey(), it appears to lack a dedicated name or tabulated form. A general expression for the distribution of the range is provided, and the author has implemented a basic version in gnu Octave, yielding good results compared to the asymptotic behavior of ptukey. The implementation is described as crude and inefficient, with an offer to share the code if there is interest.
uart
TL;DR Summary
Is there a name for the probability distribution of the range of a sample (size n) taken from a standard normal population?
I recently came across a distribution called the "Studentized Range" (for example, implemented as ptukey(x,n,dof) and qtukey(x,n,dof) in the R software package). Essentially it's the distribution of the range (max sample value - min sample value), for a sample (size n) taken from a student_t distribution (degrees of freedom dof).
Was just curious if there is a named distribution for the same thing except with the sample being taken from N(0,1) instead of student_t. Basically I was wondering if it's a distribution that's already implemented in various stats packages of if it just remains unnamed and unloved?
I know it can be approximated by just using a large dof in existing "Studentized Range" implementations like ptukey(), but wondering if it already exists as a named and tabulated distribution in it's own right.
Just updating this thread. As far as I call tell this distribution is not commonly named or tabulated. It can however be computed from the following equation, which is a general expression for the distribution of the range (W) of a sample of random variables with distribution,density F(x),f(x).
$$F_W(W) = n \int_{-\infty}^\infty f(u) [F(u+W) - F(u)]^{n-1} du$$
I have now implemented this (crudely) in gnu Octave and it gives very good agreement with the asymptotic behavior (for large dof) of the ptukey/qtukey functions mentioned above. Can post the .m files if anyone is interested, but be warned the implementation is extremely crude and inefficient, as it was just to test that the method worked.
Reference: https://demonstrations.wolfram.com/DistributionOfTheSampleRangeOfContinuousRandomVariables/
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
