Electrical DIY solar panel
  • Thread starter Thread starter Chiel555
Creating solar panels from individual solar cells is technically possible but highly impractical for most hobbyists. The quality and efficiency of DIY panels are unlikely to match those of commercially manufactured ones due to the significant investment in technology, engineering, and quality assurance that goes into professional production. While some may attempt to build custom panels for specific needs, the costs often far exceed those of standard panels, making it an unappealing option. Additionally, the complexity of the process, including soldering and performance testing, poses challenges that most individuals may not be equipped to handle. Experiments with a small number of solar cells can yield interesting results but are unlikely to produce substantial electrical power. Overall, the consensus leans towards purchasing commercially available solar panels rather than attempting to build them from scratch.
Chiel555
Is it possible to make/solder solar panels yourself from solar cells that are as good as automatically made solar panels ?
Can you give some examples of what you are starting with and what you want to make? For example, what solar cells do you have access to, and what kind of solar panels do you want to make? Are you going to make or buy the Maximum Power Point Tracking (MPPT) electronics?
https://en.wikipedia.org/wiki/Maximum_power_point_tracking
Probably not, although I suppose it depends on what's in your workshop. Give some credit here to all of the manufacturing engineers, test engineers, QA people, and financial investment that create a reliable manufacturing facility. How much money and time do you want to invest?
But why would you want to do what they do? What they do is hard and expensive.
Step 1, probably, is to give up on soldering.
Step 2 is to think about your performance and life testing plan to learn about the results of your process and improve it. No one gets it right the first time, even if they have stolen copied the IP.
https://en.wikipedia.org/wiki/Wire_bonding
PS: TLDR: No.
It seems very unlikely any hobbyist can match commercial solar panels on quality or price. I'm not sure why anyone would try when solar panels are so cheap in most places... depending on tariffs.
DIY making custom (size, form and/or power/voltage) panels is possible and is actually done if needed, but the price is usually several times larger than a standard panel would cost so at the end most people rather go back to the drawing table to adjusts on the idea than actually do it.
Not recommended.
It's a bit like contemplating building a car from spare parts or building a microprocessor with discrete components. The big-boys can afford to do it much more efficiently and get much more into a small space.
Otoh, experiments with a very few PV cells would give interesting results - but not produce any really useful electrical power. You could, for instance, investigate using a number of PV diodes to operate an LED and find the best way to connect them.
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
