Do Boiled Eggs Spin Longer Than Unboiled Ones?
  • Thread starter Thread starter samar
Boiled eggs spin longer than unboiled eggs due to the difference in their internal structure. In a boiled egg, the contents are solidified, allowing for a smoother spin without internal friction. In contrast, the liquid inside a raw egg creates viscous motion, which dissipates energy and slows the spin more quickly. This principle is similar to how a bottle of water behaves when spun, with frozen water allowing for longer spins. Understanding these dynamics clarifies why boiled eggs maintain their rotation longer.
samar
Hello
i need some help.. boiled egg will rotate for long time or unboiled and why?I hope u people will help me out..Thanx
It is easier to understand if u flip a bottle of water. The fluid will move inside and cause a bit of friction ( enough to stop it spinning after 1 or 2 turns). If u freeze the water in the bottle (plastic bottle might be better) and flip ( spin it) it will turn for a very long time. Same for the egg.
It depends on how you spin it up.
Energy is lost due to the viscose motion of the liquid in the raw egg, slowing it down faster.
Thanx Lok and other guyz for help...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
