Do Electrons, Protons, and Neutrons Generate Photons or Magnetic Fields?
Electrons generate magnetic fields only when in motion, while protons and neutrons do not contribute to magnetic fields at rest. Moving charged particles create magnetic fields perpendicular to their motion, and only accelerating charges emit real photons as electromagnetic radiation. The Curie effect explains that heating ferromagnetic materials causes thermal agitation, disrupting the alignment of magnetic dipoles and resulting in a loss of magnetism. Permanent magnets derive their magnetic fields from aligned atomic dipole moments and electron spins, which are affected by temperature changes. Understanding these principles clarifies the relationship between particle motion, magnetism, and temperature effects in materials.
protonic_mass
So, I have been reading various sources, and I am getting a little confused as to what electrons, protons, and neutrons generate when moving. Do they generate photons, or a magnetic field?
I guess what I am trying to understand is, do any of the particles listed above have a magnetic field when at rest, or just when in motion? I understand that they will emit EM at a certain velocity. I guess a second question would be, at what speed is it required in order for one electron to emit one photon.
You're talking about the motion of charged particles right? The motion of charged particles would create a magnetic field circling (perpendicular) the movement of the charges. At rest there won't be any magnetic field. And this applies only to charged particles, neutrons don't count. There's also no emission of photons when this happens.
I gotcha.
Here is what is confusing. a permanent magnet, is that moving? How can I related a moving charged particle with a magnetic field to a permanent magnet, like lodestone, or rusted iron?
what is causing the magnetic field? Wouldn't these particles have to be moving?
If that is the case, when these particles start to move alot, due to heat, doesn't the curee effect suggest that they lose their magnetism?
Sorry for all the questions, I am just confused. I don't understand how you can have a superconductor that is approaching 0K start to have an increase in its magnetic field, and if that same matter starts to approach 1000K, it loses its magnetic field due to the curee effect. You would think that if the molecules were vibrating because of the heat, that they would produce an even stronger magnetic field, wouldn't you?
You are mixing A LOT of things in one pot, especially things that aren't related to each other at all.
1. Moving charges create magnetic field - this can be described via classical E&M.
2. Any charge emits "photons", but these are virtual photons, per quantum electrodynamics.
3. Accelerating charges created EM radiation - this can also be described via classical E&M. EM radiation is "light", so these ARE photons, real ones, not virtual.
4. "curie temperature" deals with ferromagnetic material, not just simple, non-interacting charges or magnetic moment. When you heat a ferromagnet, you are adding a lot of energy to all the individual magnetic moment in side the material. They have enough energy to vibrate, spin around and tilt the magnetic moment direction, and frankly, do the hokey pokey. So the heat energy causes more disorder in the pristine arrangement of the magnetic moment. This causes the bulk material, the ferromagnet, to lose its bulk magnetism.
It would help if, whenever you want an explanation of some sources that you read, that you actually cite clearly the sources. This will tell us if you've read it correctly, misinterpret what was written, or simply read the wrong info.
Zz.
For a magnet, the magnetic field arises from atomic dipole moments as well as electron spin. Though not really an accurate picture, you can visualise an electron revolving around a nucleus as a current along a circular path. This gives rise to a small magnetisation. In ferromagnets, a lot of these dipoles are aligned in the same direction which gives rise to a net magnetisation, so in a sense the charged particles correspond to the electron "orbiting" around the nucleus.
When the magnetised object is heated above it's Curie temperature, the resulting thermal excitation causes the magnetic dipoles to orient in different directions, effectively canceling out its net magnetisation.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
