Do heavy and light cylinders roll the same?
In a vacuum, heavy and light cylinders fall at the same rate, but when rolling down an inclined plane without slippage, their behavior can differ based on mass and moment of inertia. A heavier cylinder does not necessarily reach the bottom at the same time as a lighter one, especially if they have different radii or density distributions. The moment of inertia plays a crucial role, affecting how each cylinder accelerates down the slope. Additionally, the shape of the slope can influence the path traced by the center of mass, complicating the comparison between cylinders. Understanding these dynamics is essential for accurately predicting the motion of rolling cylinders.
Gary_1
I understand why a heavy item and a light item both fall a given distance in the same time - in a vacuum, etc.
What happens in the case of a cylinder rolling down an inclined plane with no slippage? Would a heavy cylinder reach the bottom at the same time as would a light cylinder? What if the cylinders were of differing radii? What if the cylinders had a differing moment of inertia, e.g., one cylinder with homogeneous density versus another that was of higher density nearer the surface of the cylinder?
Thansk for helping me understand.
Science news on Phys.org
Thinking about it more, I'm actually not entirely sure if that statement generalizes to arbitrarily *curved* slopes. For cylindrical objects my calculation is correct. The catch is that the height refers to the center of mass and the center of mass might trace out shorter or longer paths (depending on the radius of the cylinder) if the slope isn't flat but curved. Hmm...
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
