Do I need to convert wavelength to meters
  • Thread starter Thread starter KatieLynn
    Convert Wavelength
To calculate the frequency of sound emitted by bats with a wavelength of 3.5mm, it is necessary to convert the wavelength to meters, resulting in 0.0035m. The speed of sound in air at 30 degrees Celsius is calculated as 349.4 m/s. Using the formula V = wavelength * frequency, the frequency is determined to be approximately 99829.6 Hz. Converting the wavelength is essential for accurate calculations. The discussion confirms that conversion to meters is required for proper frequency determination.
KatieLynn
The sound emitted by bats has a wavelength of 3.5mm. What is the sound's frequency in air? Assume that the bat is flying through air with a temperature of 30 degrees C.
V=331.4 + 0.6*Temp.C
V=wavelength*frequency
V= 331.4 + 0.6(30)
V=349.4m/s
349.7m/s=0.0035*f
f=99829.6hz
The only thing I'm not sure about is did I need to change the 3.5mm to .0035m?
Yes you do.
thank you :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
