Do Intervals [0, 2) and [5, 6) U [7, 8) Have the Same Cardinality?
In summary, the given function $f:[0,2)\to [5,6)\cup [7,8)$ can be shown to be both injective and surjective, thus proving that the interval A = [0,2) has the same cardinality as the set B = [5,6) U [7,8). This is done by defining the function as follows: $$f(x)=\left \{ \begin{matrix} x+5& \mbox{ if }& x\in [0,1)\\x+6 & \mbox{ if }&x\in [1,2)\end{matrix}\right.$$This function is injective because each element
KOO
Prove that the interval A = [0 , 2) has the same cardinality as the set B = [5 , 6) U [7 , 8) by constructing a bijection between the two sets
Attempt:
x ↦ x + 5 for x ∈ [0 ; 1)
x ↦ x + 6 for x ∈ [1 ; 2)
What to do next?
KOO said:
What to do next?
Prove that $f:[0,2)\to [5\color{red},\color{\black}6)\cup [7,8)$
$$f(x)=\left \{ \begin{matrix} x+5& \mbox{ if }& x\in [0,1)\\x+6 & \mbox{ if }&x\in [1\color{red},\color{\black}2)\end{matrix}\right.$$
is injective and surjective.
Fernando Revilla said:
Prove that $f:[0,2)\to [5.6)\cup [7,8)$
$$f(x)=\left \{ \begin{matrix} x+5& \mbox{ if }& x\in [0,1)\\x+6 & \mbox{ if }&x\in [1.2)\end{matrix}\right.$$
Did you mean [5,6) and not [5.6)?
Also, [1,2) and not [1.2)?
Thanks!
Of course, my fingers were clumsy. :)
To construct a bijection between the two sets, we need to show that every element in set A is paired with a unique element in set B and vice versa.
To do this, we can define a function f: A → B as follows:
f(x) =
x + 5 if x ∈ [0, 1)
x + 6 if x ∈ [1, 2)
This function maps every element in set A to a unique element in set B, and since it covers the entire range of both sets, it is surjective.
To show that it is also injective, we need to show that no two elements in set A map to the same element in set B. Since the intervals in set A and B do not overlap, this is true.
Therefore, we have shown that the function f is both surjective and injective, making it a bijection. This means that the two sets have the same cardinality.
FAQ: Do Intervals [0, 2) and [5, 6) U [7, 8) Have the Same Cardinality?
What is the definition of cardinality?
Cardinality is a mathematical concept that refers to the size or quantity of a set. It is often denoted by the symbol |S| and represents the number of elements in a set S.
How can we prove that two sets have the same cardinality?
Two sets have the same cardinality if there exists a one-to-one correspondence between the elements of the two sets. This means that every element in one set can be paired with a unique element in the other set, and vice versa.
What is the interval A = [0 , 2) and how many elements does it contain?
The interval A = [0 , 2) is a set of real numbers that includes all numbers between 0 and 2, including 0 but not including 2. It contains an infinite number of elements, as there are an infinite number of real numbers between 0 and 2.
What is the set B = [5 , 6) U [7 , 8) and how many elements does it contain?
The set B = [5 , 6) U [7 , 8) is a combination of two intervals, one from 5 to 6 (including 5 but not including 6) and one from 7 to 8 (including 7 but not including 8). It contains 4 elements, as there are 2 elements in each interval.
How can we prove that A = [0 , 2) has the same cardinality as B = [5 , 6) U [7 , 8)?
We can prove that A and B have the same cardinality by finding a one-to-one correspondence between the elements of the two sets. For example, we can pair 0 in set A with 5 in set B, 0.5 in set A with 5.5 in set B, 1 in set A with 6 in set B, and so on. This shows that every element in set A can be paired with a unique element in set B, and vice versa, proving that they have the same cardinality.
