- #36
- 8,943
- 2,948
entropy1 said:Could we speak of: "As the measured value tends to A, the measurement outcome tends to A", and: "As the measurement outcome tends to B, say, the measured value tends to B"?
I'm not sure what you mean by that.
stevendaryl said:Yes. However, it becomes a mixed state when the unobservable environmental degrees of freedom are traced out.
Lord Jestocost said:No! Physics should at least be precise when discussing fundamental and essential questions.
“Decoherence is, formally, never complete. There always remain exponentially small non-diagonal terms in the reduced density matrix, reminding us that an initial pure state remains pure according to basic quantum mechanics.” (Roland Omnes, “Results and Problems in Decoherence Theory“)
I mean that the WF evolves tostevendaryl said:I'm not sure what you mean by that.
entropy1 said:I mean that the WF evolves to
##|A \rangle|measured A \rangle + |B \rangle|measured B \rangle##
rather than
##|A \rangle|measured B \rangle + |B \rangle|measured A \rangle##
So the measured value (the cat) is fixed according to you? We have the resulting WF ##|A \rangle|measured A \rangle + |B \rangle|measured B \rangle##. So wouldn't that suggest the measured value is not fixed?stevendaryl said:Oh. Yeah, I think that there probably would be a tiny amplitude for having the "wrong" measurement result. The way I think of a measurement is in terms of an unstable equilibrium, where a tiny (microscopic) shove in one direction or another makes a big (macroscopic) difference in the outcome. For example, if you carefully balance a telephone pole on one end, a small push can make it fall in one direction or the other. Getting the "wrong" measurement result would be comparable to pushing on a telephone pole and having it fall toward you, instead of away from you. That's certainly possible (if it's not perfectly balanced, or if there are other forces pushing it toward you).
entropy1 said:So the measured value (the cat) is fixed according to you? We have the resulting WF ##|A \rangle|measured A \rangle + |B \rangle|measured B \rangle##. So wouldn't that suggest the measured value is not fixed?
So do you mean the amplitude of one of the terms in the WF goes to zero during decoherence?stevendaryl said:I'm not sure what you mean by "fixed". With the analogy of the telephone pole balanced on one end, we know:
- If there is some tiny force that shoves the pole to the left, then the pole will almost certainly fall to the left.
- If there is some tiny force that shoves the pole to the right, then the pole will almost certainly fall to the right.
- Therefore, to the extent that everything is describable using quantum mechanics, which uses linear evolution equations, if you start in a state that is a superposition of a force shoving to the left and a force shoving to the right, then you will end up in a state that is a superposition of a state in which the pole fell to the left and a state in which the pole fell to the right.
entropy1 said:So do you mean the amplitude of one of the terms in the WF goes to zero during decoherence?
entropy1 said:@stevendaryl So in which branch we end up is still a mystery? (measurement problem)
entropy1 said:@stevendaryl Ok, so if you are in a universe in which the cat is dead, you are not going to change that anymore?
Does that have to do with entropy or with decoherence?
(I hope it is not a too stupid question )
So is this possibly an epistemological matter? The environment doesn't know whether the cat is dead or alive, and so the formalism keeps both possibilities open, until the data comes in and then "both possibilities open" becomes "one of the two true", but the formalism doesn't tell us which one?stevendaryl said:##|Me\rangle (|Dead\rangle + |Live\rangle)##
and
##|Me_{dead}\rangle |Dead\rangle + |Me_{live}\rangle |Live\rangle##
entropy1 said:So is this possibly an epistemological matter? The environment doesn't know whether the cat is dead or alive, and so the formalism keeps both possibilities open, until the data comes in and then "both possibilities open" becomes "one of the two true", but the formalism doesn't tell us which one?
If the ##|Me\rangle (|Dead\rangle + |Live\rangle)## part is a matter of lack of knowledge,
...then why wouldn't the ##|Me_{dead}\rangle |Dead\rangle + |Me_{live}\rangle |Live\rangle## part also be a matter of lack of knowledge, since they are both pure states that represent a superposition?
Or conversely: why wouldn't the ##|Dead\rangle + |Live\rangle## part be an uncertain state, wherein it is possible that the cat is in fact neither dead nor alive?
stevendaryl said:No, it isn't. If an electron is in a superposition of spin-up in the z-direction and spin-down in the z-direction, it isn't just that I don't know whether it's spin-up or spin-down. A superposition is neither spin-up nor spin-down.
What I thought is that the cat is either dead nor alive, or it is one of the two, but we don't know which (as long as it is in the box). Isn't that mutually exclusive?stevendaryl said:That is the case. If the cat is in a superposition, then it is neither alive nor dead. But the point of this whole thread is that a cat CAN'T be in a superposition of alive and dead for more than a tiny fraction of second before the rest of the universe is "infected" by the cat's state.
That part is crisp clear to me.stevendaryl said:That's the whole point of distinguishing ##|Me_{dead}\rangle## from ##|Me_{alive}\rangle##. They are different versions of me. So the cat's state is determined by my state---if you were smart enough, you'd be able in theory to figure out whether the cat was alive or dead by examining me.
entropy1 said:What I thought is that the cat is either dead nor alive, or it is one of the two, but we don't know which (as long as it is in the box). Isn't that mutually exclusive?
So, is the solution that the cat decoheres, so that it no longer is in a superposition?
But doesn't that mean it was in a superposition?
So then, ##|Dead\rangle + |Live\rangle## (from your ##|Me\rangle (|Dead\rangle + |Live\rangle)##), is representing a lack of knowledge of the people outside the box?stevendaryl said:A cat is made of many, many particles. For the entire cat to be in a superposition, there would have to be basically no interactions between those particles during the time it takes for a cat to die from whatever it is that Schrodinger is using to kill it.
Doesn't matter And also, my English is a bit poor. These two things appear mutually exclusive to me:stevendaryl said:I'm sorry that every other thing you say my response is that I'm not sure what you're asking. But I'm not sure what you're asking. What are the two things that are mutually exclusive?
entropy1 said:So then, ##|Dead\rangle + |Live\rangle## (from your ##|Me\rangle (|Dead\rangle + |Live\rangle)##), is representing a lack of knowledge of the people outside the box?
- "the cat is either dead nor alive"
- "or it is one of the two, but we don't know which"
Ok, that is clear. A ket is not a mixed state. So my suggestion was wrong. But it is not clear to me what signifies the superposition then, especially in this context.stevendaryl said:If you write something as a ket, that definitely does NOT represent a person's lack of knowledge.
stevendaryl said:2. is closer to the truth,
Ok, got it. (I hope )stevendaryl said:regardless of whether you open the box, or not.
entropy1 said:Ok, that is clear. A ket is not a mixed state. So my suggestion was wrong. But it is not clear to me what signifies the superposition then, especially in this context.
If ##|A\rangle=|B\rangle+|C\rangle## then we say that the state A is a superposition of B and C.entropy1 said:Ok, that is clear. A ket is not a mixed state. So my suggestion was wrong. But it is not clear to me what signifies the superposition then, especially in this context.
entropy1 said:I understand that the situation goes quickly to ##(|observer_d\rangle |Dead\rangle) + (|observer_a\rangle |Alive\rangle)## 1, in which the cat is not in superposition for the observer. Also, nonwithstanding that the cat is isolated in the box, inside the box it is not in superposition but rather already decohered. However, when the observer has not looked in the box, his assessment of the situation is ##|observer\rangle (|Dead\rangle + |Alive\rangle)## 2, right?
So I wonder, if the cat is almost never in superposition, why the observer nevertheless is in state 2?
Also, when does state 1 occur? Already in the box, or only when the observer takes a look?
It seems to me that the formulations 1 and 2 depend on whether the observer actually observes the cat.
entropy1 said:Ok, so I'm wondering, are there two stages of decoherence the case here? First, the cat in the box on its own, and then again, when the box is opened and the observer takes a look? Which one are we talking about in this situation? I guess it matters if the box is open or closed?
Ok. So what is it about the box open or closed in Schrödingers Cat?stevendaryl said:I don't think anything very mysterious happens when you open the box, other than the observer learns what state the cat is in. That's not quantum mechanical, it's just light from the cat reaching the observer's eyes and causing changes to the state of his brain.
entropy1 said:Ok. So what is it about the box open or closed in Schrödingers Cat?
Schroedinger mentioned it, saying that the situation is resolved when the experimenter opens the box and looks in. He did not say that opening the box causes anything to happen, he was referring to the fact that the observer finds out whether the cat is alive or dead. Don't forget, Schroedinger invented the scenario to highlight a problem in the then-current understanding of quantum mechanics. He was quite specific - Heisenberg's (?) "fuzzy reality" idea would mean the cat would be in a fuzzy state. [Pause for fuzzy cat jokes.] But since then we have moved on and Schroedinger's Cat is now a familiar scenario to test various interpretations. There is no significance to opening the box other than the fact that the observer can then look inside.entropy1 said:Ok. So what is it about the box open or closed in Schrödingers Cat?
Decoherence is inevitable with most systems, especially ones that have charged particles. Even the original particle, which was thought of as being in a superposition of emitted and not emitted, would be decohered because of the recoil etc that it left on the emitting atom. But even if we constructed apparatus that created a clean superposition, the moment the particle interacts with the detector, decoherence begins. And is complete before the electrical signal even leaves the detector!entropy1 said:Ok, so I'm wondering, are there two stages of decoherence the case here? First, the cat in the box on its own, and then again, when the box is opened and the observer takes a look? Which one are we talking about in this situation? I guess it matters if the box is open or closed?
Does that mean the cat being dead or alive could depend on future events (measurements)?StevieTNZ said:Remember to keep in mind that decoherence is "FAPP". The probabilities of a mixed state do not represent something that is there in a classical sense (i.e. a cat dead). They are still probabilities of what the outcome will be. See 'Quantum Enigma' by Bruce Rosenblum and Fred Kuttner.
Not sure who you're answering, but yes, decoherence is FAPP. But even it it were total, the mixture arising from decoherence would still be improper. There need be no randomness choosing which "possible" state to actualize. The randomness then comes from the fact that the observer doesn't know which state she is in. But I'd say that such a set of states is just as much "there in a classical sense" as a single state that has been selected at random out of it.StevieTNZ said:Remember to keep in mind that decoherence is "FAPP". The probabilities of a mixed state do not represent something that is there in a classical sense (i.e. a cat dead). They are still probabilities of what the outcome will be. See 'Quantum Enigma' by Bruce Rosenblum and Fred Kuttner.
