Cyrus
- 3,237
- 17
There is no stored energy in a scuba tank (in the limit of ideal behavior), but there is (now) only stored ability to do work, by turning some of the tank gas heat, into energy...Well, if you use a tank of old (re-cooled to ambient temp) gas to do work, then the initial work you did when you compressed the gas was "stored" as heat.But the work you do to get the gas into the tank all goes into heat that goes away long before you want to use the gas for work, so it's not located anymore in the tank, so it's not stored in the tank as energy, in ANY sense. NOT as potential. The tank and associated gas doesn't weigh any more by the amount E= deltaM*c^2, etc. It does right after you fill it, and it's still hot. But not after that heat has leaked away. Yet the capacity to do work remains, and it's not stored as potential energy. Just as potential to do work as free energy dG = TdS
Ummm, no. You stored that energy in the form of pressure. You increased the pressure, therefore you increased the energy density inside the cointainer. Its not 'heat'. You can have a pressurized tank at room temperature and it clearly maintains its energy within the tank. It does not leak energy out as it reaches ambient temperature.
Pressure is a force per unit area, it has nothing to do with temperature. I can fill up an empty bottle. Right after its been filled,the temperature might be slightly above ambient. I can come back a few days later and the contents inside the tank will now be at ambient temperature. But the pressure inside the tank is still way above ambient pressure. In fact, the change in pressure will tell you how much energy was lost as the tank reached equilibrium.
Also,
Are you saying that a filled tanks weight goes back down to its original value after its cooled off? If so, this is clearly wrong.
see: http://hyperphysics.phy-astr.gsu.edu/hbase/press.html#ed
It seems like you read most of your physics off of wikipedia.
), the fact that there is still "pressure to do work" in the tank after an isothermal compression (with heat loss to the environment exactly equal to the amount of work done on the "spring") is a very peculiar property of gasses, and is a thermodynamic effect. The gas works indeed as a heat engine but we don't realize it!
