lionpauu
- 1
- TL;DR Summary
- Do Moon phases affect weighing precision on the microgram range, over several hours days at elevated temperatures?
Hi,
I'm looking to improve the precision of a system over a several hour cycle of operation of +50°C operation.
The mass is ~11g and is suspended below the balance via a factory provided point. The "sample" is enclosed within a large borosilicate flask 150mm dia x 450 mm height that is trace heated the floor is also heated and all report a 0.1°C deviation from the setpoint of 50°C. The sample itself is monitored via a non-contact IR sensor and reports a 0.1g °C max variation.
So the problem is that the sample will apparently lose up to ~0.015 g after achieving the temperature set point, and this drift will continue for several hours. I have reduced this rate by better sealing the falsk to air ingress and also I think some of the system was accumulating a static charge.
So my question is has anyone an explication of why the loss and recovery inverse to temperature, the loss in air density should increase the apparent wt, could the lunar cycle be having an impact? My balance can resolve 0.0001g and I am logging the data remotely.
There is more on my problem on twitter...
