I Do objects of differing mass fall at the same rate in a magnetic field?
Gravity is not classified as a force in the traditional sense, while magnetism is recognized as a force. The discussion suggests that more massive magnetic objects may be attracted to a magnetic source more rapidly than less massive ones. Participants are encouraged to explore the implications of this idea within established scientific principles. The conversation emphasizes the importance of understanding the underlying science behind these concepts. Overall, the topic invites further exploration of the dynamics between mass and magnetic attraction.
Constellar
TL;DR Summary
Do massive objects fall at the same rate in fields other than the gravitational field?
Gravity isn't a force in the strictest sense of the word, yet magnetism is exactly that: a force. As is strong, EW, etc.
Therefore, it's possible that the more massive magnetic object gets drawn to the center of a magnetic source at a faster rate than the less massive magnetic object. Discuss!
Hello @Constellar ,
:welcome: ##\qquad ## !​
Are you trying to offload a homework assignment, or trying to actually start a discussion ?
If the former, read the guidelines and post your best effort.
And if the latter: well, what are your thoughts ?
:smile:
[Response deleted]
Try again, this time without the attitude.
What you are speculating about is pretty well established science. How much do you know about that? What does it tell us regarding your scenario?
Yes.
Constellar said:
Discuss!
##\vec a = \vec f/m##
Likes vanhees71, Vanadium 50 and topsquark
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
