Do These Functions Qualify as Group Homomorphisms?
umzung
Are these functions homomorphisms, determine the kernel and image, and identify the quotient group up to isomorphism?
C^∗ is the group of non-zero complex numbers under multiplication, and C is the group of all complex numbers under addition.
φ1 : C−→C
z −→ (Re(z))^2;
φ2 : C−→C
z −→ z^macron (conjugate of z) + iz;
φ3 : C^∗ −→ C^∗
z −→ (z^macron (conjugate of z))^2;
φ4 : C∗ −→ C∗
z −→ i/z
I found elements in each of φ1 and φ4 to show they are not homomorphisms.
In φ2, I find that φ(z1 + z2) = (z1^macron + iz1) + (z2^macron + iz2) = φ(z1) + φ(z2), hence a homomorphism.
Identity element under addition is zero, hence Ker(φ) is z^macron + iz = 0, so z^macron = -iz. Not sure if this is correct. So φ is onto and the image is C, and not sure of quotient group?
In φ3, I find that φ(z1z2) = φ(z1)φ(z2), hence a homomorphism.
Identity element under multiplication is 1, Ker(φ) is Z^macron = 1. So φ is onto and the image is C^∗ , and not sure of quotient group?
φ1 : C−→C
z −→ (Re(z))^2;
φ2 : C−→C
φ3 : C^∗ −→ C^∗
φ4 : C∗ −→ C∗
z −→ i/z
You aren't being very clear about exactly what your specific questions are. But I'd start with the second one, which looks like it supposed to be ##\phi_2(z)=z^*+iz## (where the '*' is complex conjugate). Try and come up with a more concrete description of the kernel, say in terms of conditions on ##x## and ##y##, where ##x+iy=z##. ##\phi_2## is certainly NOT onto.
Ker(ϕ2) = {z is in C: ϕ(z) = 0}
= {z is in C: z* (complex conjugate) + iz = 0}
= {z is in C: z* = -iz.
Im(ϕ2) = the set of complex numbers.
Not sure if that makes sense.
Ker(ϕ3) = {z is in C*: ϕ(z) = 1}
= {z is in C*: (z* (complex conjugate))^2 = 1}
= {z is in C*: z* = 1}
Im(ϕ3) = the set of all non-zero complex numbers.
Any closer?
Any closer?
You are just writing ##z^*= -iz## and then jumping to the conclusion that the image of ##\phi_2## is all complex numbers. It's not. Just try and give me a solution to the equation ##\phi_2(z)=1##. Work it out. Then give me a better description of the kernel.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
