Do these substances emit formaldehyde gas when heated?
The discussion centers on concerns about whether cyclomethicone and glyoxylic acid emit formaldehyde gas when heated by hair straighteners or dryers. Cyclomethicone is widely used in various personal care products and is not expected to release formaldehyde under normal heating conditions. Glyoxylic acid, known for its strong odor and potential to irritate skin and respiratory systems, is acknowledged as a weak acid that could cause reactions. The inquiry about formaldehyde seems to stem from a negative reaction experienced during a keratin treatment application. Participants suggest that the substances are likely thermostable and that allergic reactions might be the cause of the symptoms experienced. Overall, the consensus leans towards the unlikelihood of formaldehyde release from these compounds when heated.
lk0306
Hey there,
Trying to confirm whether or not these substances emit formaldehyde gas when subject to heat of hair straightener and hairdryers. Both were ingredients in a keratin treatment i used at home and i had a crazy reaction (irritated skin, eyes, hair, nose and lungs) in the process of heating in the application process.
- Cyclomethicone
- Glyoxylic acid
Chemistry news on Phys.org
Cyclomethicone - looking at the formula I'd say it was somewhat unlikely. It is in widespread use in hair products, deodorants, skin care products (and some other products as well) and it would not be used in hair products if a hairdrier caused it to release formaldehyde.
Glyoxylic acid is reported as having an obnoxious odour, and it can be an eye, skin and respiratory irritant - it is a weak acid, so that is to be expected.
Why did you mention formaldehyde anyway? Smell?
Given that there would likely be only small amounts of these in any hair treatment, why did you ask about this pair in particular?
I got the info within seconds using google, incidentally. It was easy to find.
And the above is just my opinion. I am not an expert on these compounds, just a normal chemist.
I agree with DrJohn.
It is possible you have allergies. The compounds appear thermostable so it's unlikely to be formaldehyde unless your heat gun belongs to Area 51.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
