Strato Incendus
- 182
- 23
As a result of one of our previous discussions, I had drastically cut down the distance between the six rings of my fictional generation ship Exodus to a mere 5 metres.
Only recently did it occur to me that the airlocks on each ring existed primarily to allow the first crew to board the ship. How do you squeeze a space shuttle (or any smaller spaceship, for that matter) in between two rings that are only 5 metres apart?
A space shuttle has a wingspan of 23.79 metres. I assume it would depend on the pilots skill in how narrow a gap they could "park" a shuttle in between two rings while docking to one of them. But my layman guess would be that there should be at least twice that distance in between the rings to avoid any collisions? So 50 metres minimum, to go with a round number. Alternatively, since my rings are 64 metres wide on the outside, I could simply put that same distance in between the rings, too.
Then again, that would only make room for a current-day space shuttle. Future spaceships may be much larger, especially such that would export colonists and all their belongings to a colony ship. The latter is the reason why I want the generation ship to allow smaller shuttles to dock to the individual rings to begin with. It would of course also be possible to dock to the ship's trunk (the "central pipe"), and then transport everything onto the individual rings using the lifts going through the spokes. But that would require the lifts to be much wider than humans are ever going to need it in their day-to-day life on the ship. And of course, it would also be highly impractical.
If you only have two rings (as many depictions of fictional space stations do), you don't face this problem yet, of course, because the airlocks would probably be on the outside of the rings, not facing each other. But as soon as you have a higher number of rings (4, 6, 8...), you run into this issue.
So, how wide would you suggest that the gap between two ring habitats be (regardless of whether it's on spaceships or space stations) to safely allow a smaller shuttle to dock to one of them in between them?
