Dodgy step in the Far field approximation
The discussion focuses on the transition from the Fresnel diffraction integral to the Fraunhofer diffraction integral. It highlights the need to simplify the expression by neglecting certain terms, specifically those that are much smaller than z. The participants debate the validity of omitting terms like -2x x_0 and -2y y_0, suggesting that while they are of the same order, they can be treated differently due to their dependence on integration variables. The conversation also touches on the implications of the Fraunhofer approximation, questioning whether it is most effective away from the optical axis. Ultimately, the discussion emphasizes the nuances of approximations in diffraction theory.
Loro
The Fresnel diffraction integral is:
A(x_0 , y_0 ) = \frac{i e^{-ikz}}{λz} \int \int dx dy A( x , y ) e^{\frac{-ik}{2z} [(x - x_0)^2 + (y - y_0)^2]}
When we want to obtain the Fraunhofer diffraction integral from here, we need to somehow convert it to:
A(x_0 , y_0 ) = \frac{i e^{-ikz}}{λz} \int \int dx dy A( x , y ) e^{\frac{+ik}{z} [x x_0 + y y_0]}
So I thought we should do it as follows:
\frac{-ik}{2z} [(x - x_0)^2 + (y - y_0)^2] = \frac{-ik}{2z} [x^2 + x_0^2 + y^2 + y_0^2 - 2x x_0 - 2y y_0 ]
And then it seems that we should neglect: x^2 + x_0^2 + y^2 + y_0^2 since they're all much smaller than z.
Then we get the correct solution.
But I don't see why we could do that, and leave out the - 2x x_0 - 2y y_0. After all they are of the same order... Please help!
There might be an assumption that the aperture is small compared to the image space (x0,y0). Considering this is a far-field approximation, that tends to make sense.
Thanks,
It does, but then we couldn't neglect x_0^2 + y_0^2
Those terms do not depend on the integration variables, it is possible to pull them out of the integral. They give a prefactor, which might be irrelevant, or accounted for in some other way.
They're just a part of a phase! Got it. Thanks :)
Hold on, but wouldn't that mean that Fraunhofer approximation works best away from the optical axis - where we're allowed to say: x_0 , y_0 >> x , y ? (I don't think that's the case)
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
