A Does a DC supplied wavy superconductor give off EM radiation?
A superconductor flowing a direct current (DC) does not emit electromagnetic radiation under stable conditions. While initiating the current creates a transient magnetic field, this does not lead to continuous radiation. The magnetic field remains stable as long as the DC is maintained, with no changing dipole moments to produce radiation. Terminating the current causes the magnetic field to return to zero, but again, no radiation is emitted during the steady state. Therefore, regardless of the superconductor's shape, DC does not result in electromagnetic radiation.
binis
A superconductor has the shape of a uniform plane wave. If it is flowed by a direct current,
is it emitting electromagnetic radiation or not?
When the current is initiated, a magnetic field is radiated due to the turn-on transient.
A continuous direct current maintains a stable magnetic field, being the vector sum of all the magnetic fields from all the segments of the circuit.
When the current is terminated, the radiated magnetic field will fall back to zero.
No. The shape of the loop is irrelevant. When it is DC there is no radiation.
binis said:
have a look to this post
Have a look at the rest of that thread. The post you mention was subsequently corrected, and since you participated there you are already aware.
What produces radiation is a changing dipole moment (or higher-order multipole). A single accelerating charge does not produce radiation because of acceleration. It produces radiation because of a changing dipole moment.
A DC current has no changing moments, so no radiation, regardless of the shape of the loop.
Likes berkeman and binis
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
