- #36
- 10,355
- 1,530
Demystifier said:I agree with TrickyDicky. If Earth was a point particle, it would indeed move along a geodesic and would not radiate gravitational waves. But it is an extended object consisting of many particles between which other (non-gravitational) forces act, so that individual particles do not move along a geodesic.
In my arXiv paper I explain that a charged particle in curved spacetime also does NOT move along a geodesic, and therefore radiates.
You write:
On the other hand, if the charge accelerates,
then, even in the small neighborhood, Eqs. (11) no longer look like the Maxwell equations in Minkowski spacetime. This gives rise to a more complicated solution, which includes the terms proportional to r−1.
If we apply this to to an accelerating particle in Minkowskii coordinates, I don't quite understand how you conclude that it radiates.
Whatever the solution is, it must be static in those coordinates, because the space-time is static.
You also write
Now we turn back to the attempt to give an operational definition of radiation at large distances. In our opinion, the only reason why radiating fields deserve special attention in physics, is the fact that they fall off much slower than other fields, so their effect is much
stronger at large distances. Actually, the distinction between “radiating” and “nonradiating” fields is quite artificial; there is only one field, which can be written as a sum of components
that fall off differently at large distances. If one knows the distance of the charge that produced the electromagnetic field Fμ
ext and measures the intensity of its effects described
by (12), then one can determine whether this effect is “large” or “small”, i.e., whether the charge radiates or not.
Can you demonstrate, explicitly, such an effect ("slow falloff) in Rindler coordinates?
To insure coordinate independence, I'd like to see an argument for radiation that applies whichever coordinate system is used. Saying that "fermi coordinates are preferred because they are more physical" is sort of a cop-out. (I'm not sure that you actually said such a thing, I'm tempted to think it after a brief reading of your paper though.)
