Does a particle's mass fluctuate.
  • I
  • Thread starter maximdogger
  • Tags
    Mass
In summary, the mass of an "unstable particle" (or more accurately a resonance) is a well-defined number. It's given by the complex pole of its Green's function in (four-)momentum space, i.e., the real part of this pole is the mass and the imaginary part is its decay width, i.e., the inverse mean lifetime.
maximdogger
Is a particle's mass at minimum when viewed at maximum PEP of the wave form;
and is the particle's mass at maximum when viewed at minimum PEP? ( vis e=mc2 )
PEP?
Likes vanhees71
sine wave Peak Envelope Power.
No.
No idea what "when viewed" means.
There is however a concept of mass width in QFT for unstable particles.
Likes Demystifier and vanhees71
thanks ..I will look up mass width.
It is actually called "decay width".
This means that if you were to colled say two photons emerging from the decay of the Higgs boson. Even if you have 100% perfect dectors and instrumentation, you will still see the invariant mass of these two photons as a distribution peaking around the higgs boson mass. In some sense, this can be interpreted as "mass width"
The mass of an "unstable particle" (or more accurately a resonance) is a well-defined number. It's given by the complex pole of its Green's function in (four-)momentum space, i.e., the real part of this pole is the mass and the imaginary part is its decay width, i.e., the inverse mean lifetime.
  • Love
Likes malawi_glenn
Yup.
That is how mass can be defined for particles in qft.
  • Love
Likes vanhees71 and Demystifier
FAQ: Does a particle's mass fluctuate.
Can a particle's mass fluctuate over time?
No, a particle's rest mass is considered an intrinsic property and does not fluctuate over time. However, the effective mass can appear to change under different conditions, such as when particles are in motion or interacting with fields.
What is meant by "effective mass" in particle physics?
The effective mass of a particle refers to its mass as it appears in a specific context, such as within a material or under the influence of a field. This can differ from the particle's rest mass due to interactions with its environment.
Do quantum fluctuations affect a particle's mass?
Quantum fluctuations do not change a particle's rest mass. However, they can influence the energy levels and properties of particles in a way that might seem like mass fluctuation in certain scenarios, such as in virtual particles in quantum field theory.
How does special relativity affect the mass of a particle?
In special relativity, the mass of a particle increases with its velocity. This is often referred to as relativistic mass. However, the rest mass, which is the mass of the particle when it is at rest, remains constant.
Can interactions with fields change a particle's mass?
Interactions with fields, such as the Higgs field, can give particles mass. However, once a particle has acquired mass through such interactions, its rest mass remains constant unless it undergoes a fundamental change in its properties or identity.
